Will a TBE cause a CEL??
I'm thinking of buying a TBE since I hear that's the best hp gain for the buck. I was wondering if anyone can tell me if a TBE will cause a CEL? I have no mods done to the car at this time. I will eventually think about buys a Cobbs AP but that's in the future. I saw this TBE on Ebay, http://cgi.ebay.com/ebaymotors/02-06...02172001QQrdZ1 , which is only $350 shipped and comes with an up-pipe too. Now I know that it's not a name brand exhaust but it looks like it will get the job done and has a nice polished finish too. Let me know what you guys think of both ideas. Thanks!!
Car Info: 2005 WRX STI
i started getting cel codes after i installed just my downpipe on my 05 sti. Got more after i installed my cat back greddy sp2. After i got the Cobb AP no more cel codes.
E
E
Car Info: Vishnu up-pipe, 5/64" mod
Well my car threw a CEL with just the downpipe. So then I got the Perrin CEL fix and it worked for about 5 months. Now every now and then I get a random CEL Code number P0139.
Originally Posted by chgabbs
Good info, but that sucks to know I have to spend more money to get rid of the cels.
As for whether or not the TBE will throw a CEL, if you replace any fo the cats, you'll probably get a CEL, but it isnt anything big, just telling you that the cat which is now on your garage floor, isnt working right
Originally Posted by MBasile
most vendors sell something you splice into the wiring of the rear o2 sensor to get rid of the cel you get form removing a CAT. Typically it is less than $20.
E
Originally Posted by scarface
It will still throw cel codes. I had this cel fix on my downpipe. Just wont throw them as often. Or usually it would only happen when i was in 5th or 6th WOT. I dont think its bad, the ECU just doesnt like what it sees.
E
E
well it wont throw a CEL if you replace the up-pipe and get rid of that cat. But yes it will throw a CEL if you replace the down pipe. The perrin CEL fix works but like what was previously said before it wont throw a CEL as often.
you might want to double check your cel fix wiring....mine has been in for a long time with 2 rally-x's and a track day in addition to normal spirited driving and hasnt thrown any CELs again. But yes, its not a problem, its just that the ECU sees that more pollutants are coming through the exhaust than should, so its telling you the cat is bad
E
Just buy 2 spark plug defoulers from Kragen for a couple bucks, screw em together and install with your o2 sensor. I did this back in March, still no cel's with 3'' tbe w/ high flow cat and catless uppipe.
hayakunai
Apr 9, 2005 11:02 PM
jaypowell78
Mar 10, 2005 07:29 PM
(==ImPrEzAWR==)
May 17, 2003 11:22 PM
