what to expect after car is tuned?
Old Dec 28, 2006 | 05:23 PM
Lazyboy's Avatar
Car Info: 2004 wrx impreza
hey guys hope everyone had a good Christmas. well i want to know about dyno tuning. i scheduled my car to be dyno tuned by Dyno Flash in connecticut. i want to know the risks and expectations i should focus on when getting it done? what is the most important step in having my car dyno tuned? should i be worried? sorry very new at this.
thanks
tristan
Old Jan 2, 2007 | 09:52 PM
MO REX's Avatar
Car Info: 02 PSM WRX
Here's a good read on the subject http://www.projectwrx.com/caringforyourvehicle.pdf
What have you done to the car so far?
Old Jan 5, 2007 | 03:30 PM
Lazyboy's Avatar
thanks mo rex. well
hks bov
vf39
sti tmic
greddy exhaust/
dp/uppipe
turboxs manual boost controller
perrin pulley
ACt clutch stage 1 and flywheel
turbo xs utec
Old Jan 6, 2007 | 10:42 PM
MO REX's Avatar
Did you upgrade the fuel pump and injectors?
Old Jan 7, 2007 | 03:27 AM
Wingless Wonder's Avatar
You might also check with Dynoflash to make sure they are willing to tune your UTEC. Many tuners can tune a UTEC-equipped car but some don't want to use anything other their licensed tuning tools. It is, of course, their choice to make.
Old Jan 7, 2007 | 08:30 AM
Lazyboy's Avatar
oh yah mo rex sorry. i got the sti pinks and 250 walbro fuel pump. =P
they told me to buy another set of spark plugs. any recommendations as to which ones?
TRISTAN
Old Jan 7, 2007 | 09:52 AM
MO REX's Avatar
From what I've read you should go one heat range colder for every 75–100hp you increase so I'd guess 1 step colder NGK coppers or platinum's. They say Coppers are better for performance but since it's such a PITA to change the plugs in our horizontally opposed engines I always go with platinum's since they last longer.
FYI, I'm running Cobb stage 2 with the OE turbo in my car and I have no 1st hand experience with your setup. Your best bet might be to ask your tuner what heat range to go with but I'm pretty sure he will tell you to go 1 step colder.
Wingless Wonder brings up a good point but I'm guessing you and the tuner have talked this over already.
Old Jan 7, 2007 | 10:09 AM
MO REX's Avatar
Here are some part #s but I'd double check before buying since I'm only 99% sure they're right.
NGK/Copper/BKR7ES/WRX/one step colder
NGK/Platinum/BKR7EGP/WRX/one step colder
NGK/Iridium/BKR7EIX/WRX/one step colder
Old Jan 7, 2007 | 10:48 AM
VRT MBasile's Avatar
more power, smoother running car....more fun
Old Jan 8, 2007 | 07:22 PM
Lazyboy's Avatar
thanks mo rex. you think with my setup i'll hit at least 270?
tristan
Old Jan 9, 2007 | 02:20 PM
MO REX's Avatar
Not sure but depending on the dyno your tuner uses you might. Do you know what kind of dyno he has?
Old Jan 11, 2007 | 07:17 PM
Lazyboy's Avatar
not sure mo rex but ima find out on the 19th.. wish me luck!
Old Jan 12, 2007 | 08:58 AM
7scooby's Avatar
all i can say is call vishnu
Old Jan 14, 2007 | 07:10 PM
Lazyboy's Avatar
who is vishnu?
Old Jan 14, 2007 | 09:42 PM
7scooby's Avatar
vishnu tuning...shiv is genius "vishnutuning.com"
