Walbro Fuel Pump Users! Read This Thread!
Car Info: 2017 WRB WRX Premium
And a few more:
http://forums.nasioc.com/forums/show...albro+strainer
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
Originally posted by raazin
i think i had a little problem with the fuel pump because sometimes it made whining noise when the car is just idealing
Gino, you can believe what you want. I am going to try replacing the strainer. It is worth a shot. If you didn't read the post above where I state the problem my car is having, it is the same problems these people described. Obviously, this problem doesn't happen with all of the Walbro fuel pumps. I may have bought one of the pumps with a problem. I don't know yet.
If it works, I will post the results and you will be the first to know it. If it doesn't work, you were right, and I will be looking for a replacement pump.
Kurlee Daddee
(THE ORIGINAL)
Last Sunday, 12/20, I replaced the Walbro strainer for the OEM strainer and right away noticed a difference in the way the car idled. I let the gas get low today, a little under a 1/4 tank, and tried a worst case scenario to see if I would experience the same problems as before. I took a jaunt up Bear Creek road, and had the gas sloshing back and forth in the tank. Even under boost, I did not get any knock or EGT's to tell me there was a problem. The car ran a lot better than it did with the Walbro strainer. The Walbro pickup that was on my car was a little more than 5mm shorter than the pickup of the OEM strainer(not the teabag). I am also wondering what the size of the Walbro pickup hole/s are in ID compared to that of the OEM pickup. The changing of strainers worked on my car, but remember all cars are different. Sorry to burst your bubble Gino.
Kurlee Daddee
(THE ORIGINAL)
Kurlee Daddee
(THE ORIGINAL)
Originally posted by mikkyo
Kurlee Daddee, which Walbro pump do you have(341 or 342)?
Kurlee Daddee
(THE ORIGINAL)
Car Info: 2003 Impreza WRX Sedan Midnight Black Pearl
Huh. I wonder if that is the issue?
The 342 is a direct replacement, which is what I bought.
The pump, sock, feed line, everything look almost exactly the same.
The shape of the internal sock support was a bit different, if I recall correctly.
I read about the issues with the sock before I got mine, and so I looked real carefully at everything before installing.
I forget if I used the stock sock or not, have to look in my parts box, but I remember thinking there is no way it could possible matter.
I checked the sizes, height when empty full, how the sock sat, the tubing diameter, etc.
I haven't seen the 341 firsthand, but now I bet it has a different sock.
http://forums.nasioc.com/forums/show...p+install+sock
From what is says in the link above, the 342 is the direct replacement, whereas the 341 is not. Now people need to be wary of both types. If you get the 341, use the stock sock.
Kurlee Daddee
(THE ORIGINAL)
dan2304k
Wanted
May 25, 2006 04:28 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
mav1c
Mar 1, 2003 09:40 AM
