vishnu piggy back question
Old Apr 8, 2004 | 08:04 AM
WRX_2NR's Avatar
Car Info: 04 WRX
I have Xede (Vishnu piggyback user tuneable chip)
My WRX is totally stock right now. There is a huge improvement with Xede running.
Fuel tuning, timing adjustments, boost control option, datalogging
The car feels like a totally different vehicle with Xede running
If you have the opprotunity get it. Plus if you do anything to the car like getting an uppipe or downpipe you can just load a new map and tune it.
I would recommend though getting a stock airbox. I have heard all kinds of problems running and aftermarket intake. The intakes cause MAF reading problems
Old Apr 8, 2004 | 08:10 AM
Egan's Avatar
Re: vishnu piggy back question
Originally posted by chxh8me
i have the opportunity to buy a piggy back programmed for stage 0. at the moment i only have a catback and a CAI (i know i know, but i bought the car used from the dealer and it came with it)....and i just ordered some IC hoses today.
so my question is.....without having bought an uppipe yet, or anything else that may be included in stage 0, will my car get any benefit from installing this, or will it see adverse effects?
thanks
If the Xede is programmed for Stage Zero, then it is programmed for a car with an uppipe, colder range spark plugs, and possibly IC hoses. You won't want to run this programming with the stock uppipe.
However, the beauty of the Xede is that you can adjust the map yourself or load ready made maps into it. I would suggest you download the Stage SubZero map from Vishnu's website and load that into the Xede. It will better match your current mod level (after you get rid of the CAI). Then if you add an uppipe later, you can just load the Zero map back in.
Old Apr 8, 2004 | 08:20 AM
WRX_2NR's Avatar
Car Info: 04 WRX
wrXratd
You are correct. He would run a Subzero map
W/out uppipe you run Subzero
w/ uppipe you then can run Zero
And like wrXratd said you use that map for a base and tune it for your car
Old Apr 8, 2004 | 09:21 AM
WRX_2NR's Avatar
Car Info: 04 WRX
Yes the 03 & 02 airboxes are the same
If you ever want to change your setup its better to have Xede
Old Apr 13, 2004 | 12:11 PM
pcowan's Avatar
Car Info: '04 STi - RallyX beast
thanks
I think the big overlooked question is: is this an Xede or Unichip? From what I know, for the current WRX stage0 it's an ecutek remap. Before that was the Unichip and I'm not entirely sure that the Xede was ever used for a WRX stage0. Regardless, Shiv had a pretty good policy with the Unichip where he'd offer to burn any map in accordance to what you had installed (assuming he had something on hand), but that was 2 years ago.
Old Apr 13, 2004 | 12:13 PM
Egan's Avatar
There are Xede maps available for Stage SubZero, Stage Zero, Stage One, and Stage Two configurations.
sti2ner
Jun 18, 2005 10:49 PM
duma
Mar 2, 2005 08:32 PM
duma
Jul 30, 2004 12:51 AM
bigben
Mar 3, 2003 07:06 AM
David@VISHNU
Dec 10, 2002 07:40 PM
