VF39+STi injectors - which Accessport map?
Old May 30, 2004 | 01:14 PM
TripleBlkWRX's Avatar
Car Info: 2013 WRX
Im thinking of going with this setup but i wanted to know what base map is anyone using if they have an Accessport. VF34, VF30, or maybe Stg2 w/ stock turbo???
Old May 30, 2004 | 01:44 PM
RussB's Avatar
Car Info: $200,000 sports car
you're going to need a custom tune with the VF39 since none of the Cobb maps are tuned for it.
Give S-Squared a call at (916) 631-7440 and ask for Nate. They're in Sacramento and are authorized EcuTek dealers, and they really know what they're doing.
Old May 31, 2004 | 11:10 AM
Jimbo's Avatar
I actually thought about giving a used VF39 a try with the Cobb VF30/34 reflash, but was able to get a new VF34 for only $150 more than what used VF39s go for. You can always give it a try, but everytime I see someone use a non-recommended part with off-the-shelf maps they end up making less power than they should. I would agree with Russ that you should consider S-Squared, iSpeed or Vishnu for a custom map. We are spoiled in the Bay Area with all the tuners around.
Jimbo
Old Jul 14, 2004 | 05:35 PM
Krinkov's Avatar
I think a 30/34 map would be safe with a be safe with a 39 since its basically the same turbo with a smaller turbine housing for better spool(39=P17 housing, 30/34=P18 housing) so if anytinhg you would have a bit more margin of safety using a 30/34 map on a 39 since its going to have a bit less up top where you would possibly run into problems, just my 2 cents
cwc16
Sep 7, 2012 12:00 PM
A170123W
Jul 6, 2007 07:30 AM
carletto
Jul 23, 2005 03:20 PM
mr mike
May 2, 2004 08:17 AM
