Utec vs. Link
Old Feb 5, 2003 | 02:41 PM
jjunior887's Avatar
Car Info: 22
I don't think the ECU will learn around the UTEC, the UTEC just tells the ECU what it wants to know to get the proper adjustments from it.
You should get the same thing every time, at least I have from what I can tell.
I agree with skywalker, the user interface is really simple once you get the hang of it and understand what you're doing.
Don't know much about the upgraded turbos and such, I'm only running a stage 2+.
I have no experience with the link other than what I've read on the boards, it seems like it's more for a serious tuner(someone who wants nothing to do with the functions of the stock ecu) than the UTEC.
There's been plenty of negative things said about this one too, just do a search, you'll see what I'm talking about.
Can you tell who has what here?-James
Old Feb 5, 2003 | 05:53 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
I have a LINK for sale with serial LINK for a lot less then new. PM me if you decide to go this route.
I do agree with Bill about needing to adjust the UTEC every now and then. The UTEC I would assume just induces offsets to the OE computer. So if the OE computer uses it's fuzzylogic and changes parameters to xx value, then the UTEC will only change whats programmed into it. Just imagine that you put in a value of + 5 somewhere, and the ECU decides to change it's own value to something else and you either end up with an actual value of +2 or perhaps a negative number...
Then again I dont own a UTEC so I can't really comment on how it really works. But I do own a LINK, and a standalone is what you want for complete control over your engine.
Old Feb 9, 2003 | 05:49 PM
teiva-boy's Avatar
emailing you now
Old Feb 13, 2003 | 01:02 AM
teiva-boy's Avatar
Both the LINK or UTEC will do that with ease. But I dont know if it's for someone with "low knowledge." An ECUTEK system would be better or something that has premade maps like the UTEC or XEDE system.
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
RavSpec
Feb 6, 2004 09:07 AM
sweetwrx
Dec 2, 2003 08:58 PM
nekoball
Nov 10, 2003 03:44 PM
IS2Scooby
Aug 7, 2003 12:22 PM
