Tactrix 1.3
Old Jan 11, 2011 | 07:53 AM
Jimboi's Avatar
Car Info: 2005 sti
Tactrix 1.3
I have an 05 Sti and I want to know if 1.3 would Be just as good as the 2.0? I would like some feed back from ppl using open source and how they like and not like.
Old Jan 12, 2011 | 12:02 AM
Jimboi's Avatar
Car Info: 2005 sti
Anyone with experience?
Old Jan 12, 2011 | 08:28 AM
I dont have any sorry
Old Jan 13, 2011 | 04:28 PM
Jimboi's Avatar
Car Info: 2005 sti
Man. This sucks. Lol
Old Jan 13, 2011 | 04:40 PM
Yeah sorry
Old Jan 17, 2011 | 10:56 PM
STINGR3's Avatar
Car Info: sti
1.3s or u is fine just beware of imitations. I actually like it better than the 2.0 cause it's a bit more durable. See if you can locate the 1.3 and 2.0 on this picture.
Regards,
Ron
Old Jan 18, 2011 | 08:05 AM
Jimboi's Avatar
Car Info: 2005 sti
The 1.3 would have to Be the black one cuhz I kno the 2.0 has that clear shell to it. Would I need anything else when I use the 1.3 besides te software? Like a flasher jumper thing? Lol thanks
Old Jan 18, 2011 | 12:17 PM
STINGR3's Avatar
Car Info: sti
No since you have a 2005 sti all you need is to connect the green test connectors on the pictures above on the driver side top left of the kick panel( or where your left foot is at, just look down and up). The 2.0 is mainly tailored for the canbus ecu type cars( works on most older subaru models too where the ecu is supported) like the 2008 sti and up and some 2007 subaru models or evo x.
Ron
Old Jan 18, 2011 | 02:17 PM
Jimboi's Avatar
Car Info: 2005 sti
Fasho. now im good. as far as tuning goes, what do you recommend for stage 2 tune? all i have is an intake,catless dp,full 3inch exhaust(blitz Nur spec R) also am i able to disable the cat sensor with the tactrix? cause the cel light is always showing. thanks
Old Jan 19, 2011 | 10:33 PM
STINGR3's Avatar
Car Info: sti
Yes, you can disable the cel codes pertaining to the catless dp. Your setup is enough to make some good power maybe bigger injectors or a walbro fuel pump if you decide to run race gas or e85 down the line. But if your just learning how to tune by yourself then keep it simple until you get good at it maybe even revert back to stock factory air intake box for simplicity sake.
Ron
Old Jan 20, 2011 | 04:21 AM
Jimboi's Avatar
Car Info: 2005 sti
Good to know. Thanks! Ordering my cable this weekend!
Old Mar 27, 2011 | 03:38 PM
Jimboi's Avatar
Car Info: 2005 sti
anyone got a good stage 2 open source map for 05 sti? my current setup is
Spt short ram intake
3inch Hard turbo inlet
helix catless dp
custom mid pip
blitz nur spec R cat back.
stock vf39
i just want a good running map plz. thanks
Old Mar 27, 2011 | 05:35 PM
Jimboi's Avatar
Car Info: 2005 sti
I need a map plz.
Old Mar 28, 2011 | 05:06 PM
Jimboi's Avatar
Car Info: 2005 sti
Maps!! Plz
evsoul
Jul 17, 2016 01:50 PM
pwnx0rz
Mar 8, 2007 02:56 PM
boostfed
Feb 17, 2007 10:41 AM
robsrex
Jan 27, 2007 04:35 PM
goixiz
Oct 17, 2006 06:24 PM
