Tactrix 1.3
Car Info: 2005 sti
Tactrix 1.3
I have an 05 Sti and I want to know if 1.3 would Be just as good as the 2.0? I would like some feed back from ppl using open source and how they like and not like.
I actually like it better than the 2.0 cause it's a bit more durable.
See if you can locate the 1.3 and 2.0 on this picture.
Regards,
Ron
Car Info: 2005 sti
The 1.3 would have to Be the black one cuhz I kno the 2.0 has that clear shell to it. Would I need anything else when I use the 1.3 besides te software? Like a flasher jumper thing? Lol thanks
Ron
Car Info: 2005 sti
Fasho. now im good. as far as tuning goes, what do you recommend for stage 2 tune? all i have is an intake,catless dp,full 3inch exhaust(blitz Nur spec R) also am i able to disable the cat sensor with the tactrix? cause the cel light is always showing.
thanks
thanks
Ron
Car Info: 2005 sti
anyone got a good stage 2 open source map for 05 sti? my current setup is
Spt short ram intake
3inch Hard turbo inlet
helix catless dp
custom mid pip
blitz nur spec R cat back.
stock vf39
i just want a good running map plz. thanks
helix catless dp
custom mid pip
stock vf39
goixiz
Oct 17, 2006 06:24 PM
