sti utec problem
Old Nov 26, 2004 | 07:47 PM
imprezav8's Avatar
Car Info: blue sti
sti utec problem
i have a stock sti with a utec with turboxs stage 1 map 93 gas in ny and I am geting knock around 4000-6000 rpms, i need some help
Old Nov 27, 2004 | 11:12 AM
SGOSWRX's Avatar
Very intersesting. I'm wondering what kind of effect you would get from the
Stage 2 Program. I've heard so negitive things about the stage 1 program. But who knows. My STi runs great (with the exception of the slight hesitation at
2800 rpms) with the stage 2 program. Yes I'm also running a full turbo back exhaust but I get no knock at all even at high boost levels (18psi).
Just a suggestion.
Old Nov 27, 2004 | 07:32 PM
imprezav8's Avatar
Car Info: blue sti
i also have used the stage 2 map by mistake and it knocked 5 time as much
Old Dec 12, 2004 | 08:17 PM
mmboost's Avatar
These base maps are not meant to be plug-n-play. You are running a map that who knows under what atmospheric conditions it was made, and you're running it in the beginning of a NY winter. You should expect some knock! The base maps are meant to be a starting point for tuning. Get a wide band O2 sensor and get tuning or get it professionally tuned. Even if you get it professionally tuned you'll be retuning it as the weather hits other extremes. If you don't want to do all that learning sell your UTEC and get a custom reflash.
Also, check out the UTEC forum in wrxhackers.com if you want to play with your maps. Its really not hard to make your map safe. READ THE MANUAL. Do some driving at the conditions where you knock and log it by pressing "1" at the top screen. Then post it at wrxhackers in the UTEC forum.
Me, I like the tuning and learning.
jason
IMPREZIN
Aug 11, 2006 10:58 AM
minisiu
Jun 17, 2006 02:14 PM
a1cwrx
Sep 1, 2005 06:46 PM
gruppe-s
Jan 28, 2005 06:16 PM
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
