sti nitrous
Old Jun 22, 2003 | 09:19 PM
adamRmr's Avatar
Car Info: WRX STi black/Gold rims
I was thinking about the same thing for my STi.I want to go with the NX intercooler CO2 kit its only $349....What do you think about this kit
Adam
Black/gold STi
Old Jun 24, 2003 | 09:59 PM
WREXXED's Avatar
Car Info: 2002 WRX
STi should handle a 50 shot fine, since the WRX can. Remember to turn the boost down when you start because the N2O will raise it up a few lbs.
Good Luck, and keep us updated on the resluts.
Old Jun 26, 2003 | 01:24 PM
WREXXED's Avatar
Car Info: 2002 WRX
For boost control you can use a manual boost controller(MBC) or a electronic (EBC). MBC you install if the engine compartment and have to pop the hood and dial in your boost, gets real old fast. EBC is mounted right there next to you and you can dial in your boost via a couple of buttons.
I would first consider your long term goals for the car. If you plan to just spray a 50 shot then you can get away with just a MBC or EBC but if you plan on uprgrading the car further I would look into some form of management. With the UTEC you can control boost, timing, and fuel....have seperate maps(N2O map, street map, race gas, etc...) This would be the safest way to spray. Check it out www.turboxs.com
I have found that the N2O will raise the boost about 2psi, so I would start at 12 psi and spray and see how much it rises and then work your way up to a max of 14.5-15. Not sure exactly what the STi can handle stock.
Old Jun 26, 2003 | 08:36 PM
ScoobySaurusRex's Avatar
according to shivs dyno results the STi makes about 17psi. check it out
http://www.vishnutuning.com/sti_dyno.htm
also are any of you guys experiencing any pinging or det like other STi owners. If you are I would hold out on mods incase there is a recall. you never know.
cpc993
18
Oct 23, 2005 02:09 AM
NotoriousWRX
Feb 4, 2003 05:32 PM
optimalrage
19
Dec 24, 2002 09:42 PM
DoctorNick
14
Nov 27, 2002 03:28 PM
Imprezinator
Nov 27, 2002 10:03 AM
