stage 1 map questions
Car Info: WRX STI 07
I have an hks uppipe and a walbro255 fp and I have an AP on the way (should be here Tuesday) I was wondering if the ots stage 1 map would take care of the slight modifications..im kinda afraid i may be running a little on the rich side due to the upgraded fuel pump without A/f ratio adjustments.
its kinda wierd putting on a fuel pump with out putting injectors and a turbo on
unless you are boosting the stock turbo to hell there is no real reason to have an upgraded fuel pump
yes you are probably running rich
but rich >>>> lean
but rich >>>> lean
lburrrna
Jun 28, 2006 05:26 PM
wvinfernovw
Feb 7, 2006 10:48 PM
carletto
Jul 23, 2005 03:20 PM
