Smog check with a tec-II
Old Nov 29, 2002 | 11:58 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
You will never be able to "normally" pass SMOG in California with a TEC. Unless you cannot see it and big fatty plug wires make it almost impossible. At the same time, some mechanics can close their eyes on "visual" inspection and if your car passes the sniffer, you should be ok.
- Alex
Old Nov 30, 2002 | 05:35 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Pulling the bulb from the check engine light may not help if they check to see if it comes on with the key before the engine is started.
Old Dec 3, 2002 | 04:30 PM
KGB's Avatar
KGB
Car Info: 2000 Impreza 2.5RS BRP
Unhappy
Well, government is never friendly to modded cars - even if you pass the sniffer, because it's modded, you can't pass. Good thing up here they haven't started using OBD-II as a pass criteria. As long as you have a cat and passes the sniffer, you should be good.
Old Dec 3, 2002 | 09:30 PM
BADWRX's Avatar
Car Info: 09 E90 M3 SEDAN w/DCT
Man,
When I got bagged, and refered to a referee, I went in with the PE1820, 565cc Injectors, a CEL, and ...that was it...
You know what they tripped on? The stupid Apexi pen type turbo timer! Since it monitors the rear O2, they were pissed. They allowed me to disconnect it, and pull the battery cable to reset the CEL.
Passed with flying colors. They looked at the engine bay and asked if it was stock...and I was like, "Yeah, I just pulled off the heat shields!"
That was a CARB smog ref mind you! Screw this socialist state. I am going to register my car in Nevada, so as to avoid the mayhem the next go around with the law!
Andy
