Pulling CEL codes
Old Nov 24, 2002 | 06:02 PM
ImprezaRSDriver's Avatar
I have heard of this method. I know that SVX owners that are OBDI do this to find out what CEL code they had thrown. Basically once you connect two pins you count how many times the CEL flashes and it will let you know specifically what it is.
Old Nov 25, 2002 | 09:44 AM
Dick Fitzwell's Avatar
Originally posted by IMPREZIV
Never heard of that method before, but Ill try it tonight and see what happens. If I get electrocuted, Im suin'
Pete
wouldn't you have to have a cel to see?
Old Nov 26, 2002 | 04:22 PM
jjunior887's Avatar
Car Info: 22
Originally posted by Arcanum
No, it runs through a test kinda mode. It flashes some number that means no CELs are present. I don't remember the exact pins to connect. I belive one was ground and the pin right above it. I take no responsibility for fried ECMs
/\rcanum
I thought that's what the 2 green connectors under the dash on the drivers side were for. When you put them together and turn the key on it sends the ECU into some test mode or something.
Old Nov 26, 2002 | 09:28 PM
Mulder's Avatar
Car Info: 02 WRX WRB
That doesn't sound right, you shouldn't be able to do this on a 98. Anything 96 and up would be OBDII, and AFAIK there is no way to do the paper clip trick on any of these. OBDII is a more-or-less universal standard among all mfrs. and requires a scan tool to read stored data. Older OBDI cars had proprietary protocols for each mfr. and most allowed for reading codes through the check engine light.
Old Nov 26, 2002 | 09:31 PM
Mulder's Avatar
It does activate a test mode but has nothing to do with being able to read codes. This is used at the factory or dealer but is of little use to us.
Old Nov 27, 2002 | 12:58 PM
jjunior887's Avatar
Car Info: 22
That's what i meant, I need to be a little clearer next time. I know it doesn't help us much I was just stating that it put it through some sort of diagnostic test.
Old Jan 2, 2003 | 10:05 PM
RotarFreak's Avatar
Car Info: 95 1.8 fwd auto -> 95 2.5 awd 5sp
this might be of use to me.
i just converted my car from obd 1 to obd 2 and i've yet to put the engine back. When i turn the key for the first time, as much as i dont want it, i expect to see a check engine light.
If before i turn the key, i activate test mode, will it tell me any possible problems without actually starting the car, and possibly causing some damage?
Thanx
edzwrx2
Mar 4, 2008 08:42 PM
chrisdeaner
Jul 8, 2006 11:50 PM
BLOWN
Nov 15, 2003 03:47 PM
etal
May 31, 2003 04:36 PM
BashoPoem
Feb 3, 2003 09:08 AM
