proposal: open ecu project
Old Dec 23, 2004 | 01:22 PM
mmboost's Avatar
I think the problem with this is the hardware. I'm a fairly technical person and I wouldn't enjoy soldering a board together. I think that's where it will kill the process for most people. If you are going to manufacture them, you have to be in business already to pay the manufacturer enough to build them... and then you're in business... and then you begin to realize why these commercial systems cost what they do.
Also, what do you do for logging?
jason
Old Dec 23, 2004 | 02:15 PM
gordy's Avatar
Car Info: '03 WRX WRB
how about an open source software stand-alone engine management project built around the latest fast 32bit embedded cpus from intel or ibm. that way you could rally up support from all the independent tuners not just the subaru people.
lets call it Shmotec. with faster cpus we could use advanced algorithms taht auto-tune the car based on feedback from a g-tech, replace lookup tables with functions using readings from fancy sensors, we can have software for simulations based on data collected from tons of different setups. the thing could drive crazy **** from camless or pnuematic heads to wacky fuel systems that mix optimal solutions of alcohol and nitrous on the fly.. all kinds of innovations would happen first in the OSS community if there was one.
Old Jan 2, 2005 | 01:44 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Colby,
excellent idea... I'm really glad someone finally stepped up to organize something like this. I'd very much like to contribute to this project as much as possible and I think my help will be beneficial.
Jason,
the hardware issue you speak of isn't nearly as bad as you may think. There are already plenty of USB to OBD or serial to OBS adapters and harnesses available. No intermediate device is necessary, so such an adapter is actually quite simple to wire up or manufacture. Believe it or not, but hardware part of this project is actually the simplest part.
-- Ed
imHELLAslow
May 29, 2009 08:53 AM
Weak Sauce
Feb 15, 2006 05:05 PM
GotBoost?
Jun 9, 2005 10:22 PM
topnotchwrx
May 19, 2005 07:20 PM
Top
