need help on STI ECU reset
Old Dec 18, 2004 | 05:42 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I have an 02 WRX and my manual tells you not to run anything lower than 91 octane. If you don't have 91 octane gas available you should try to avoid running the car to hard to avoid detonation/knock. My understanding is that the ecu will pull timing when knock occurs.
To reset the ecu just undo the negative battery cable get in your car, hold the break pedal until the tail lights die out, reconnect the negative battery cable and that's it. After you fill up with good gas it might be best to run it a little before the reset.
Old Jan 2, 2005 | 06:53 PM
mw1029h's Avatar
Car Info: 04 STi blk cloaked team blew member
Originally Posted by Scud!
Dear all, I would like some help on a funny case I experienced. Just a week ago I have installed a light weight pulley on my 2004 STI. I suspected that the mechanic had disconnected the battery during the installation but just before I went to the mechanic I filled my STI with regular petrol (presumedly low as it was an emergency and there was no super unleaded around). Now, I am experiencing lost of power (not at max boost I pressume some sort of timing retard) which I can't figure out which had caused this (the bad fuel or some other reason). I have heard from others that it might be the bad fuel that caused the lost of power. Could someone in this forum tell me how to reset the ECU in order to get things back to normal after I filled the car with some high octane fuel? (my STI is still stock with no other mods except for the light weight pulley). Any inputs would be appreciated...
Did you figure it out if not i'll tell you let me know
got boost
Apr 23, 2007 11:26 AM
EQ Tuning
36
Sep 27, 2004 10:56 PM
EQ Tuning
Sep 3, 2004 12:35 AM
johndoe
Feb 2, 2004 03:56 PM
Patrick Olsen
Jan 5, 2003 01:03 AM
