n2o question
Old Jun 22, 2003 | 03:24 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
For starters, you want a wet kit. There is no substitute for a turbo car.
A purge kit is really only for the die hard racer where every hundreth counts.
A bottle warmer is essential.
Other then that, a 50-75 shot is very reliable. A 150HP shot works as well for about 4 runs as per STEALTH-WRX Guaranteed a 12 sec run!
Brand is up to you.. But I prefer either NOS, or Zex.
Old Jun 24, 2003 | 10:05 PM
WREXXED's Avatar
Car Info: 2002 WRX
I would suggest one heat range colder plugs, non-platinum. Definetly a wet kit, and a fuel pump would be nice but not totally necessary. Your also going to need some way to control boost, when you spray you need to turn the boost down because it will rise on the N2O. Also if you don't already have a uppipe get one, downpipe wouldn't hurt either. Not sure about the ZEX kits but if you go with NOS the "soft plume nozzle" is a good upgrade for a WRX.
Purge kit is not necessary.
Enjoy
Old Jun 25, 2003 | 10:08 AM
WREXXED's Avatar
Car Info: 2002 WRX
Walbro GS342...it's the cheapest and direct fit(only minor modification needed)
or the GS341(little more mod needed), supra fuel pump, or 300ZXTT pump....both of these need mod as well.
Old Jun 25, 2003 | 10:12 AM
WREXXED's Avatar
Car Info: 2002 WRX
On a side note, some people will say you don't need the pump but I figure it's only $90 and easy to install so why not. Plus in the future if you upgrade the turbo, which after feeling to 50 shot you will definetly want to, you will already have the pump installed.
Old Jun 25, 2003 | 11:14 AM
WREXXED's Avatar
Car Info: 2002 WRX
The pump is located in the trunk, I removed the back seats to access it easier. Pretty easy install.
Check out www.quantum-racing.com
They have a good right up with pics on the install.
brucelee
Aug 1, 2009 10:59 AM
acsWRX
Jul 6, 2005 07:07 PM
5LTRETR
Apr 8, 2005 02:30 PM
legacy2003
Jun 8, 2003 04:43 AM
Mach5WRX
Dec 27, 2002 02:40 PM
