Max boost setting with UTEC and ABC
Old May 11, 2003 | 12:14 AM
TWRX's Avatar
Car Info: '06 STi Black/Gold
Gman,
If I'm remembering correctly, the directions recommend that you adjust the ABC so that it'll peak to 16.5 lbs in 4th gear between 4000-4500 rpms. 3rd gear doesn't allow the turbo to boost enough, if you use 3rd gear, you'll have overshoot in 4th and more overshoot in 5th.
Each complete turn out should increase the boost by about 1 lbs, according to Turboxs. Adjust in small increments.
Have you read the directions that came with the UTEC, it outlines most of the tech stuff in there. Also you may want to to the Turboxs site and read the other installation instructions.
Hope that helps.
Tyler
Old May 12, 2003 | 12:00 PM
TWRX's Avatar
GMAN,
Yeah, this is supposed to be at WOT.
There's a great conversion site that I found.
Pressure conversion
Hope this helps.
Tyler
John OBrien
Engine and Drivetrain
May 7, 2009 10:03 AM
Ash
Apr 5, 2005 10:10 PM
Ash
Mar 29, 2005 10:54 PM
emephgee
Mar 17, 2005 11:40 PM
XwrxX
Dec 17, 2002 07:14 AM
