Loosing force at 5000 rpm
Old Oct 31, 2005 | 08:32 AM
Gomy's_WRX's Avatar
Car Info: Silver 04 WRX
I have a problem with my 04 wrx when it at 5000rpm, the car began to loose force as if dont have enough gas. Does somebody have experience the same??
Old Oct 31, 2005 | 12:57 PM
Wingless Wonder's Avatar
Your description of the problem is a little vague.
Has it always done this?
If not, when did it begin happening?
What mods are on the car (engine)?
How many miles do you have on the odometer?
Is your fuel economy still the same as before the problem began (sometimes a dropoff in economy indicates a problem).
Old Nov 1, 2005 | 02:28 AM
Gomy's_WRX's Avatar
Unhappy
The problem began 2 weeks ago, I only have a manual boost controler and cat less down pipe and yes my fuel economy is going down. My car is a 04 WRX with 22K miles. I have a WRX but feels like a Corrolla
Old Nov 1, 2005 | 03:42 AM
Donkey's Avatar
Car Info: 02' WRX
Smile
Take off the MBC,sell it and use money towards engine management.Also learn to research modifications heavily before buying to save money and repair bills.Your factory ecu need to be controling the boost not an mbc.Depending on outside temps,throttle position and air density boost needs to be changed accordinly.An MBC will do none of the above.Do you have a boost gauge?What is your max boost you are hitting in 4th or 5th gear?
Old Nov 1, 2005 | 04:59 AM
Gomy's_WRX's Avatar
Id take off the MBC alredy and the car still have the same problem... My doubt is why the problem is exactly at 5000 rpm, below this the car run great!
Old Nov 1, 2005 | 09:14 AM
Donkey's Avatar
Car Info: 02' WRX
04-05 wrx's have had problems in a ol/cl delay.Usually getting a basic em upgrade fixes this.
Old Nov 1, 2005 | 09:38 AM
Gomy's_WRX's Avatar
Sorry about my ignorance but you have to explain me what is ol/cl and em?????
One guy told me about change the sparks, what do you think?????
Old Nov 1, 2005 | 02:55 PM
Just abbreviations - 'ol' and 'cl' delay is open loop and closed loop delay, respectively. 'em' is engine management such as an EcuTek reflash or Cobb AccessPORT.
The open/closed loop delay may be your problem but this doesn't explain why you haven't experienced the power drop off after 5000 rpm before two weeks ago, with or without the manual boost controller hooked up.
If you haven't already done so, please check underhood for any loose vacuum hose connections (or cracked vacuum hoses) where your mbc was installed. Also check the intercooler hose connections underneath the intercooler and at the throttle body.
I don't think your spark plugs are the problem unless you cranked up the boost so high with the mbc that the spark plug electrodes were damaged by running lean under boost. On the other hand, changing them won't do any harm and spark plugs don't cost very much. If you change them, examine the electrodes and porcelain section that are exposed to combustion chamber for unusual wear or melted electrodes or cracked porcelain.
As Donkey has asked, do you have a boost gauge installed? Without one, you have no way of knowing what adjustments with the mbc were doing to your engine. With a working boost gauge, you would be able to see if the power drop off above 5000 rpm corresponds with a drop in boost pressure.
Old Nov 1, 2005 | 04:02 PM
vspdave's Avatar
Car Info: WReX K3
Funny that Wingless would mention IC connections! I had a broken hose clamp off the intercooler cause a similar problem not too long ago.
Hopefully its nothing terminal!
Old Nov 2, 2005 | 01:48 AM
Gomy's_WRX's Avatar
Thank you guys Ill try everything that you have mentioned! and yes , I have a boost gauge and dont have problem with boost
Old Nov 22, 2005 | 06:31 AM
Gomy's_WRX's Avatar
I dont know what to do with my car????????????????
Id try everything
Old Nov 25, 2005 | 11:58 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
It sounds like the ECU is sensing some severe knock above 5k RPM and pulling timing to avoid it. The result is much less power in that range. Maybe you got a tank of bad gas, but either way, running an MBC on an untuned 04/05 wrx is just asking for trouble.
Old Dec 5, 2005 | 08:12 AM
Gomy's_WRX's Avatar
I had found the problem, it was just a bad uppipe, the cat was broke I just swap a 2006 cat less uppipe and solved problem....thanks to all!!!!!!!!!
Old Dec 5, 2005 | 09:00 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
Sorry, I didn't read all the prior posts but I'd def. consider your clutch. Your car is modded and I'm sure you drive it so I'd consider it.
Old Dec 6, 2005 | 06:38 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
A destroyed uppipe cat is actually just a bi-product of your real issue... the MBC. In an 04+ WRX, using an MBC causes a serious lean condition every time you go into any significant boost. This lean condition results in extremely high EGT's which caused damage to your uppipe cat. Please don't ignore the root of your issues because continuing to run your car in this manner will certainly reduce the life of your engine.
Top
