Link ECU and no bigger fuel pump?
i'm thinking about getting the AVO turbo kit from rallitek. But when i e-mailed rallitek about why the AVO kit does not come with a larger fuel pump? Correct me if i'm wrong but the Link ECU is going to force the injectors to inject more gas but how are they going to make up the diffrence in pressure? Also why does the Link ECU negate the use of a RRFPR?
Sorry about the amount of question but i can not find answers.
With a LINK ecu, you can set EXACTLY how much fuel you want the injectors to put out. That is the point of a complete standalone engine mangement system. You can make it as rich or as lean as you want.
As for not using a RRFPR, you dont need it as you can add larger injectors and tune for it. A RRFPR is really only a bandaid for small adjustments.
drifter04
Nov 5, 2008 10:38 PM
dan2304k
Wanted
May 25, 2006 04:28 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
