install a/f gauge with out Oxygen Sensor Kit??
Old Sep 30, 2003 | 08:15 PM
minisiu's Avatar
does any one know a way to install a/f gauge with out buying the auto meter Oxygen Sensor Kit?
well, i read about the problem of WRX o2 sensor, the per cat sensor is 5v and after cat is 1v, so if i installed on the after cat sensor it is not going to read right! If i install on the per cat one it is alos not going to read right! So does any one know how to install a a/f gauge with out spend alot of $$$ because the o2 sensor kit cost $99.99
Old Oct 3, 2003 | 11:53 PM
You can install it, but without the proper sending unit, it won't read correctly. And if you aren't using a wideband sensor, it won't read correctly outside of a narrow range of ratios.
Old Oct 4, 2003 | 01:36 AM
mario's Avatar
Tru that man a A/F ratio gauge is just there took look pretty in your unless you want to spend 400 bucks on a wide band 02 sensor.
Peaty
May 30, 2008 09:58 AM
diz
Subaru OEM Parts For Sale
Jul 9, 2007 03:41 PM
cleofis
Aug 31, 2005 12:19 AM
TimChick10
Feb 6, 2005 09:48 AM
imprezapilot
Jan 6, 2004 10:22 PM
