How much psi
Old Sep 13, 2005 | 03:25 PM
Gomy's_WRX's Avatar
Car Info: Silver 04 WRX
How much psi
How much psi have a stock wrx, and how much can handle it????
Old Sep 14, 2005 | 10:01 AM
Double Phister's Avatar
Father Time
Car Info: This aint a bag. It's a shipment.
A stock WRX have 13.5 psi. I think all WRX's can handle it.
Old Sep 14, 2005 | 11:26 AM
subie OCD's Avatar
Car Info: 04 STi
some push 20psi+ with bigger turbos and supporting mods on the 2.0L
I wouldnt expect it to last long at that level though
Old Sep 14, 2005 | 07:42 PM
hk_subi's Avatar
Car Info: wht 04 wrx=RIP 02' GPW s2000
there are some stock-turboed wrxs pushing 19+ psi, daily-driven. However, 15-16 psi would probably be a safer level.
Old Sep 14, 2005 | 11:54 PM
snicklous's Avatar
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
i run a vf-34 with all supporting mods with cobb e.m. it pushes 18 psi max. it is a daily driver and i get the same gas milage as i did stock.
Old Sep 15, 2005 | 12:50 AM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
To answer your question in full, with a proper boost conrtol you can push a constant 16.5 psi right below fuel cut-off (17 psi). Some people will claim that a stock WRX with BC (boost control) can handle up to 18 psi with no affects. I own an Apexi AVC-R BC and love it. You can control boost in every gear to fit the curve. Electronic over manual no doubt. Just for kicks I think the stock WRX runs 9.5 psi in 1-3rd and 14.5 in 4th and 5th. Not 100% on that though.
Old Sep 16, 2005 | 12:14 AM
snicklous's Avatar
i believe it is 13.5 psi max in 4th and 5th. i know i don't push any boost in first gear and didn't when the car was stock either.
Old Sep 16, 2005 | 01:10 AM
taerron's Avatar
19+ on a stock turbo?
Old Sep 19, 2005 | 01:03 AM
snicklous's Avatar
i believe 19 psi is the max before you start running into heat problems with the turbo.
Old Sep 19, 2005 | 09:47 AM
unstble's Avatar
Car Info: WREX
Stock is 13.5psi - I recently installed my boost gauge, and it only says I am getting 10 psi Max, and my pressure is at 16.
Is the 16 pressure reading normal?
Old Sep 19, 2005 | 12:08 PM
truWRXtacy's Avatar
Car Info: 2005 WRX
i got a ecutek from vishnu, and it runs 16psi (or so they say)
Old Sep 19, 2005 | 01:11 PM
subie OCD's Avatar
Car Info: 04 STi
It should. Shiv dyno tuned my wagon, my boost will peak at around 16-17 psi wot in 4th on the freeway. This is with pulled timing.
Old Sep 19, 2005 | 03:45 PM
unstble's Avatar
Car Info: WREX
I meant my vacuum pressure sits at 16-18
Old Oct 4, 2005 | 03:14 PM
st0ckwRx03's Avatar
Car Info: WRX 03
i have an 03 wrx and i my boost spools up to 14psi and go down to 13.5psi from 1st to 5th gears. i'm stock everything except for the deleted snorkus. i have an autometer boost gauge, if that matters they all should the same tho.
chris
Old Oct 4, 2005 | 03:30 PM
unstble's Avatar
Car Info: WREX
Yeah, I need to get this looked at soon
