how much for protune
It depends on where you go. Not sure where you are from, but on the east coast the Protuner that I chose only charges 300 for your first protune and then 150 for every mapp they make for you after that. A lot of places tend to charge on an hourly rate instead of a flat rate. Above anything though make sure you choose a place that is pretty reputable and has worked on many cars with great success, even if it cost you a little bit more in the end.
sabrebluewhale
Jul 20, 2008 07:53 PM
