How much hp I will add to my stock wrx with a boost controler
Old Sep 15, 2005 | 07:54 AM
Gomy's_WRX's Avatar
Car Info: Silver 04 WRX
How much hp I will ad to my stock wrx with an boost controler
How much hp I will ad to my stock wrx with an boost controler and how it will improve my 1/4 ET?
Old Sep 15, 2005 | 01:20 PM
GotBoost?'s Avatar
Car Info: 2003 PSM STi
dont waste your time/money on a boost controller....esp. if your car is totally stock. You'd be better off spending the extra money and getting a ECUTEK reflash/tune. The stock ECU is good for controlling boost up to about 20-21psi. But on a stock car, I wouldnt boost past 17.5-18psi max. With a reflash/tune ALONE....with NO OTHER MODS, you should yield about 30-45whp (depending on how "safe" of a tune you want. A radical tune will give you more HP, but could also make you run too lean, a good "safe" tune will be VERY streetable, and will give you a big smile, for quite awhile.)
my 2¢
-Ted
Old Sep 15, 2005 | 02:17 PM
1reguL8NSTi's Avatar
Car Info: 05 STi
You could add a lot of horsepower if your an idiot. The question is, how long will you keep it? A boost controller is a great way to blow a perfectly good engine up. Good luck.
Old Sep 15, 2005 | 03:22 PM
gilmore25's Avatar
Car Info: 05 LegacyGT,06 Black STI Will be home Soon
Get a Reflash and let it control the Boost it will be alot safer.. If you wanna try the boost controller then set it to 15 lbs i wouldn't go over that.
Old Sep 15, 2005 | 07:04 PM
Cyrus923's Avatar
Car Info: 2004 WRX in WR Blue
If you cabnbe modest then an electronic BC is a great deal. A reflash is nice but you cannot up or lower the boost if you want to in many different settings. I have an Apexi AVC-R and I love it. I can control all aspects of boost and keep mine running a safe 16.5 psi, below fuel cut-off. From that I prob. see about 20-25 hp gain.
Old Sep 28, 2005 | 10:13 AM
unstble's Avatar
Car Info: WREX
So, is it safe to raise boost with a boost controller to 15psi without tuning? Is this what the consensus is here?
.:: 808 STi ::.
Feb 16, 2004 11:43 AM
DWNSHFT
Dec 7, 2003 02:02 AM
RBREX
Oct 1, 2003 03:59 PM
digitalroojp
Jan 13, 2003 03:49 PM
