How do I read the Boost guage???
Old Nov 29, 2003 | 04:14 PM
It reads in some ridiculous metric unit that has nothing to do with reality. I think you're wanting to see .11 whatever-they-are of peak boost.
Old Dec 3, 2003 | 10:47 AM
Wingless Wonder's Avatar
I don't know if this is what you're asking, but:
lbs of boost = mPa * 145.0376
For example, .10 mPa * 145.0376 = ~14.5 lbs of boost.
Old Dec 27, 2003 | 09:26 PM
Maniac's Avatar
Car Info: Silver 2002 WRX Sedan
www.convert-me.com my friend! Excellent source for unit conversion!
Here's link for your particular question!:http://www.convert-me.com/en/convert/pressure
Old Dec 28, 2003 | 02:50 PM
Great link Maniac!
Old Dec 31, 2003 | 11:18 PM
huffyrex's Avatar
Car Info: 2003 WRX
to convert bar to psi multiply bar x 14.503
to convert psi to bar multiply psi x .0689
Old Jan 1, 2004 | 12:12 AM
Uncle Scotty's Avatar
I really like 'convert'...see:
http://www.joshmadison.com/software/convert/
outstanding and real easy...converts damn near anything to whatever you need....I keep a shortcut on my toolbar.
Old May 18, 2004 | 12:30 PM
Maniac's Avatar
Boost seems a bit high. Is it a TurboXS unichip that's in your car? How many miles on the car and how long has it been running that boost?
Factory electronics limit boost to 17psi, so the only way you could get more than 17psi is if the Unichip is altering the signals. It may be OK if the unichip is tuned to work at that boost level. I think the stock turbo would not be running too efficiently.
Another important thing is to see if the ehxaust is stock or modded. Having a large catless downpipe would help reduce some of the thermal loading by reducing post-turbo back pressure.
Anyway, the short answer is: I dont know if it is safe to run 17.4 psi boost on you car. It all depends on the tuning and other mods.
Anyone else?
Old May 18, 2004 | 04:50 PM
SsTiNgEr77's Avatar
Car Info: 2002
i would lower the settings on your MBC, the stock turbo i've read is only efficient up to 16 psi.. anything after that its just blowin hot air
Old May 18, 2004 | 05:18 PM
Maniac's Avatar
If it looks like it had a bigger turbo and IC, then the Unichip is likely tuned for those. My advice to you is to turn the boost down to stock level (14.5-15psi) and get some more info about the TXS parts that are still on it.
Old May 20, 2004 | 01:42 AM
Maniac's Avatar
Try to reconnect the factory boost controller.
