Greddy perf E-01
does any one knows how to tap the rpm wire (brown) n the option wire (yellow) to the ECU.... and knows use the boost control???
not too sure about installations but to set the boost you will go on automatic boost set and set on how much boost you want for low and high and so on......but the trick is to step in full throttle on third gear until the meter hits the desired boost level.....you might to repeat until the little blinking icon on the screen dissapears ....that means that the boost is now saved ....good luck!
yeah... i ve read the instrustuction manual and i kinda know how to set boost, but i still didn't find out how to tap the RPM wire.. anyway thankz for the replay...
