engine management 2.2 n/a
Old May 6, 2003 | 07:59 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
a/f gague ( will this work off the stock 02 sensor? )
A narrow band sensor is useless for tuning. It's more of a dancing light then anything. What you want is a wideband O2 sensor and display kit. www.techedge.com.au has some reasonably priced ones. I have one And they keep getting better with each revision
something to increase fuel pressure (new pump, fuel pressure
riser? help!)
larger injectors (probably turbo legacy)
A fuel pump is a good idea, but an adjustable regulator is probably not. An adjustable regulator is more of a band-aid fix when you are running short of fuel. If you were experiencing some high IDC's, you could bump up fuel pressure a tad and make up for it. But that IMO is poor tuning. Thats where the larger injectors come in. That is the best way to compensate for a lack of fuel. Of course it's not the cheapest.
However to get the most out of your engine and it's performance, you should look into some sort of engine managment. I would say a LINK would be a good start as there is a lot of good vendors like i-speed on this board that can assist you for a very reasonable rate. Of course there are many other universal engine managment systems out there worth looking at as well like Autronic, SDS, TEC, and more.
Imprezer
Jan 23, 2003 05:00 AM
odyss3y
Nov 26, 2002 01:32 PM
stealth-wrx
Wanted
Nov 22, 2002 11:30 AM
i-speed
Nov 22, 2002 04:34 AM
