Does EcuTek reset after prolonged power disconnect? (was: Please Help Me I'm scared!)
Old Jan 27, 2006 | 02:00 PM
STI TAHITI's Avatar
Car Info: STI 2004 2.5L
Please Help Me I'm scared !!!!!!!!
Hi Everyone,
I live in Tahiti (French Polynesia) and i'm a newbee to forums. I really need to have an answer to my question because i'm really worrying about my engine life.
Please can anyone tell me if it is normal to run an A/F ratio around 13,5 to 14+???? I know that it is very lean. I don't have any CEL, the car's running good but i'm sure something is wrong.
So there is the story: I crashed the front of my car in a rally race and my APS DR725 has been touched (big hole on it). So i fixed everything with new bumper etc.... and I bought a new FMIC (the same model than i had). So it took about 1 month to get all the parts since tahiti is very far from everything. Then when i started the car evertyhing was OK except the A/F. I don't have A/F gauge but just an apexi turbo timer that can show aproximatively the A/F. Before my crash when i was pushing the car very hard it showed around 11- to 12+ but now even if i'm spirited driving it's still around 13 to 14+. The only things that changed from before is the NEW APS FMIC, the ambiant temperature (now it's very hot in Tahiti, around 105°F) and i think that's all. I was wondering if the engine management from ECUTEK could has been reseted since i disconected the battery for more than 1 month.
Please let me know what you think. I'm really happy to share your community it's a little bit more fun than BMW's forums (My wife and i own an M3 E46 with a Stage 2 supercharger that pulls about 500 BHP).
Thank you and best regards.
Old Jan 27, 2006 | 09:07 PM
Wingless Wonder's Avatar
Origami posted by STI TAHITI
Some EcuTek reflashed ECUs will reset to 'valet' mode after a battery disconnect. Turn the ignition key to the 'on' position (no need to start engine), press and hold throttle pedal to the floor, depress dashboard rear window defroster button. Release throttle and turn off rear window defroster. You may start the engine normally. Not all EcuTek reflashes will default to this mode. Some custom reflashes will toggle a slightly different tuning map instead of valet mode.
This may not be your problem anyway since the valet mode does not cause a car to run that lean under boost, it mainly limits boost to about 7 or 8 lbs.
Disconnecting battery power for several weeks does not cause the ECU to lose an EcuTek tune. The reflash is flashed to non-volatile memory meaning it is not power-dependent to retain the tune.
You might consult with the tuner that supplied your EcuTek reflash or reflashed ECU. You might have to send the unit back to them.
Old Jan 27, 2006 | 11:53 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
Question
Are you serious? How in the hell did you figure out that combo?
Old Jan 28, 2006 | 04:48 AM
Origami posted by depdivr
https://www.i-club.com/forums/showth...toggle+defrost
https://www.i-club.com/forums/showth...ult#post569897
That's actually what I have to do to toggle back to my high-output map with my off-the-shelf Vishnu tune after the battery has been disconnected. The early EcuTek reflashes from Vishnu did not incorporate this toggle. I don't know if other tuners follow the same practices when it comes to reflashes or not.
Old Jan 28, 2006 | 11:00 PM
depdivr's Avatar
Really! I had no idea... well you learn something new every day.
Old Feb 1, 2006 | 11:47 AM
subie OCD's Avatar
Car Info: 04 STi
Are there any negative effects from resetting the ecu too many times? Before I did the 2 CEL fixes (for uppipe and rear o2) I was resetting the ecu alot.
Old Feb 1, 2006 | 03:56 PM
No negative effects. Keep in mind that the service manual specifies disconnecting the battery for any electrical repairs as well as many mechanical repairs for safety reasons. Each time a technician disconnects the battery, the ECU is reset, so I doubt there is any harm done when we 'try this at home'.
Old Feb 1, 2006 | 04:26 PM
STI TAHITI's Avatar
Please can anyone tell me how come i'm running more lean right now than before my crash? I just need to know where to start? Should i buy a Hydra EMS to retune the ecu, should i buy a new fuel filter or clean the injectors, check the hoses that can have moved during the shock....i really don't know.
i<3dirt
Oct 20, 2014 10:26 AM
EQ Tuning
36
Sep 27, 2004 10:56 PM
EQ Tuning
Sep 3, 2004 12:35 AM
johndoe
Feb 2, 2004 03:56 PM
spdkills
Feb 12, 2003 12:37 AM
