cobb engine check light on, pls help! P0244
Old Jun 8, 2007 | 06:58 PM
lburrrna's Avatar
Cool cobb engine check light on, pls help! P0244
hey guys,
Wat does this code means: P0244 Turbo Wastegate Selenoid "A" Range/Performance
Mods:
fp18g
STI TMIC
Stock injectors
invidia catted downpipe
HKS Hi-power catback
RA sti tranny 5 speed
Currently milage: 16,xxx
i was driving normally on the freeway and decided to WOT in 5th gear. i felt like a hesitation (i guessing a fuel cut) CEL came on with P0244
P2044: Turbo Wastegate Selenoid "A" Range/Performance
thanks!
Old Jun 10, 2007 | 08:48 AM
LunarHonour's Avatar
Car Info: STI 2006 White Stage 666
You over boosted and hit fuel cut (the fuel to the engine got cut off because the boost went higher then the limit set in the ECU). Your wastegate probably was not able to evacuate enough exhaust to prevent this.
Old Jun 10, 2007 | 06:24 PM
lburrrna's Avatar
Smile
ok, i believe is the weather. it get cold here and foggy here in california, right now its fine. the CEL went out by itself! anybody experience this? i have no more CEL!
Old Jun 12, 2007 | 08:24 AM
testes1010's Avatar
it is completely normal for 06-07 WRX to get boost creep......especially in colder weather & in 5th gear at low load(ie: low rpm, WOT)...
Old Jun 20, 2007 | 03:25 PM
Lorry's Avatar
CELs usually go away if the problem has been resolved. Some of them require a number of successful stop/start cycles. If you google, you can find reference sheets describing the CEL #s and how they are set/cleared.
Bolt21
May 1, 2010 11:47 PM
tanz1983
Feb 7, 2007 08:55 PM
tanz1983
Jan 16, 2007 07:41 AM
MaVz
Dec 27, 2005 01:13 PM
silver satin
Sep 10, 2004 07:09 AM
