Cel Fix
Old Dec 5, 2004 | 07:02 PM
wagoon's Avatar
Im pissing fuel away----
Quick question for anyone who might know; Ive been running with my CEL on for a little bit now, Up and TBE, injen intake,turbosmart BOV -waiting for my utec to come back from getting professionally tuned, I didnt want to run just a base map and/or mess with engine management specifics on my own--figured id do it right the first time! Anyway the error code P0420 is a cat inefficiency code since the car has no cats what so ever------when the cel fix (lets say from perrin or whoever) deletes that code, will the ecu govern distribution of fuel correctly once again? Its been running rich as hell. Its worse than my 2.5 GT was. Please help I cant afford the fuel anymore.
Old Dec 5, 2004 | 11:24 PM
hockeygod's Avatar
Car Info: 2004 WRB WRX
bump. im curious also
Old Mar 14, 2005 | 07:54 PM
JAYSPEED's Avatar
Car Info: 02 Wagon
bumwondering if anyone has any imput from this.
Is there anyone that has done the Mech fix v. the Electronic????
Old Mar 15, 2005 | 04:39 PM
P0420 doesn't make you use more fuel. Your right foot does that.
Old Mar 16, 2005 | 07:12 PM
Hoppie's Avatar
Car Info: '13 WRX Hatch OBP
I've got the mechanical cel fix and have thrown a cel a couple times. The all knowing BAN SUVs is right P0420 doesn't effect anything. You just gotta lay off the gas.
All you have to do to reset the cel is to unplug your battery, and press the brake a few times. Reset mine both times. Hope that helps.
Old Mar 16, 2005 | 08:31 PM
I'm not all-knowing dude, I just keep my mouth shut when I don't know the answer.
P0420 will usually come back quickly though, so it's worth finding a way to defeat it rather than resetting your ECU every ~250 miles and losing your fuel and spark learning.
Old Mar 16, 2005 | 10:51 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
so I take it you're catless?
I never had a problem with the mechanical fix. Over 4,000 miles.
Old Jun 26, 2005 | 11:46 PM
ryan05's Avatar
i had the same problem, i bought a kit that fixed that problem http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
heres the link
although my engine light is still on due to a #1 cylinder miss fire, my car runs so rich that 2 1/2 foot flames shoot out of it and when i look at my exhaust at idle its spits gas, i can only get about 14mpg driving concervitive
any ideas how to fix the miss fire??
ryan
Old Jun 27, 2005 | 01:59 AM
Sounds like you have a MAF sensor issue, or a boost/vacuum leak.
Old Jun 27, 2005 | 06:45 PM
ryan05's Avatar
really?!? do you know how i could fix that or what i should do?
Old Jun 28, 2005 | 01:33 AM
Take it to a local qualified mechanic or dealer and tell him what's up. The only other thing I can think of that would cause that is a stuck injector. They are still stock right?
Old Jun 28, 2005 | 11:41 AM
ryan05's Avatar
yes, everything fuel related is stock, however i do have a APEXi intake
Old Jun 28, 2005 | 02:34 PM
Try taking that out. Many intakes cause bad MAF readings. See if that fixes it.
Old Jun 28, 2005 | 03:25 PM
ryan05's Avatar
ok thank you so much for your input
esracer
Mar 16, 2004 11:56 AM
fungracing
Jan 9, 2003 02:04 PM
mrtrex
Vendor Group Buys/Specials
Dec 23, 2002 05:50 PM
gruppe-s
17
Dec 21, 2002 04:08 PM
jjunior887
Dec 15, 2002 02:20 PM
