Cant figure out why this knock occurred (utec)
Old Jul 21, 2004 | 02:24 PM
mmboost's Avatar
First off, I seem to get knock sparsely now, but when it hits the count is almost always in the double digits. Here's a bit of log. At the point where it knock, the overboost (19psi + ) doesn't happen until two log lines after the knock. The only thing I can think of so far is that boost was way down at that point (<9psi) and I dumped another 0.5% of fuel into the engine... knock from being overly rich? Note the +14deg correction! yow!
[click here for map]
Code:
                    Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %                    deg   duty   deg    %   (CL)    V
 3775  -2.4 2.8  17  00    00   14.7 +36.6   14.5 ECU.   -1.0 ECU.   2.5
 3968  -2.4 2.9  18  00    00   14.7 +38.1   14.7 ECU.   -1.0 ECU.   2.6
 4115  -2.2 3.0  20  00    00   14.4 +38.2   17.2 ECU.   -1.0 ECU.   2.7
 4391  -1.4 3.2  29  10    00   15.2 +31.6   36.1 +19.0  -0.7 ECU.   3.2
 4796  +1.1 3.8  86  30    00   rich +23.1   59.1 +20.0  -0.9 249.00 3.6
 5333  +5.1 4.2 100  60    00   rich +23.6   83.7 +19.0  -0.9 250.00 3.9
 5737 +10.2 4.3 100  90    00   rich +23.9   87.8 +15.0  -0.3 250.00 4.0
 6410 +13.9 4.4 100  90    00   rich +27.3   94.7 +16.4  -0.5 250.00 4.0
 7092 +15.7 4.4 101  80    00   rich +29.3   93.6 +19.3  -0.3 250.00 4.0
 7107 +16.4 4.4  73  80    00   rich +26.8   83.8 +19.5  -0.4 250.00 2.6
 6447 +10.4 3.6   0  00    00   rich +10.8   44.5 +19.0  -0.9 ECU.   3.2
 5952  +4.1 3.1   0  00    00   rich  +8.6   27.3 +19.0  -0.9 ECU.   2.7
 5491  -2.4 2.8   0  00    00   rich +12.9   20.2 +19.0  -0.9 ECU.   2.6
 4728  -6.5 3.6  65  10    00   rich +23.9   45.6 +19.3  -0.8 252.50 3.3
 4403  -3.0 3.8 100  30    00   rich  -2.4   54.0 +18.8  -0.5 245.00 3.5
 4516  +3.3 4.0 100  70    00   rich  -3.5   68.7 +14.0  +0.3 245.00 3.7
 4734 +10.4 4.0 100  90    00   rich +17.7   72.2 +13.0  +0.6 245.00 3.8
 4880 +14.5 4.1 100  90    00   rich +19.5   73.3 +13.0  +0.1 245.00 3.8
 5020 +17.4 4.1 100  90    00   rich +22.2   77.2 +13.0  -0.1 250.00 3.8
 5208 +17.2 4.2 100  90    00   rich +23.7   78.6 +13.0  -0.2 250.00 3.8
 5393 +17.0 4.2 100  90    00   rich +23.5   81.5 +14.4  -0.2 250.00 3.9
 5555 +17.4 4.3 100  90    00   rich +23.6   83.1 +15.0  -0.3 250.00 4.0
 5797 +17.0 4.3 100  90    00   rich +23.7   91.3 +15.0  -0.3 250.00 4.0
 5984 +17.6 4.4 100  90    00   rich +24.5   91.1 +15.1  -0.4 250.00 4.0
 6218 +17.8 4.4 100 100    00   rich +25.5   91.4 +15.7  -0.5 250.00 4.0
 6289 +17.6 4.4 101  90    00   rich +27.9   94.0 +16.0  -0.5 250.00 4.0
 6435 +17.6 4.5 101  90    00   rich +28.1   94.4 +16.7  -0.5 250.00 4.0
 6640 +16.8 4.4 100  90    00   rich +29.0   93.9 +18.1  -0.6 250.00 4.0
 6720 +16.4 4.4 100  80    00   rich +29.3   99.5 +19.0  -0.3 250.00 4.1
 7017 +16.1 4.4  90  90    00   rich +29.3   93.1 +18.4  -0.5 250.00 3.3
 6361 +10.8 3.6   0  00    00   rich +10.8   45.0 +19.0  -0.9 ECU.   3.2
Old Jul 21, 2004 | 02:25 PM
mmboost's Avatar
Code:
 5817  +4.7 3.2   0  00    00   rich  +8.6   27.5 +19.0  -0.9 ECU.   2.7
 5420  -1.0 3.3  40  10    00   rich +16.7   46.0 +20.0  -1.9 250.00 3.3
 4967  -3.4 3.8 100  10    00   rich +26.6   57.0 +20.0  -1.5 245.00 3.5
 5089  +1.7 4.2 100  60    00   rich +22.3   77.0 +19.0  -0.7 250.00 3.8
 5184  +8.8 4.2 100  90    17   rich +19.6   78.8  +5.0  -0.1 250.00 3.9
 5151 +15.7 4.3 100 100    00   rich +19.2   80.2  +5.0  -0.2 250.00 3.9
 5167 +19.2 4.2 101 100    00   rich +20.3   80.6  +5.0  -0.2 250.00 3.9
 5291 +19.6 4.2 100 100    00   rich +20.5   83.3 +13.2  -0.3 250.00 4.0
 5265 +19.6 4.2 101 100    00   rich +20.7   81.8 +13.8  -0.3 250.00 3.9
 5473 +19.0 4.3 100 100    00   rich +21.2   85.4 +14.0  -0.3 250.00 3.9
 5592 +18.2 4.3 100 100    00   rich +21.3   86.3 +14.0  -0.3 250.00 4.0
 5602 +18.4 4.3 100 100    00   rich +21.2   86.9 +14.0  -0.3 250.00 4.0
 5649 +17.8 4.3 100 100    00   rich +21.6   86.3 +14.0  -0.3 250.00 4.0
 5797 +17.4 4.3 100  90    00   rich +21.8   91.7 +15.0  -0.3 250.00 4.0
 5952 +17.6 4.3 100  90    00   rich +21.8   91.5 +15.0  -0.3 250.00 4.0
 6361 +17.8 4.4 100 100    00   rich +22.4   94.8 +15.0  -0.5 250.00 4.0
 5973 +17.6 4.4 100 100    00   rich +22.4   94.1 +15.2  -0.5 250.00 4.0
 6060 +18.0 4.4 100  90    00   rich +24.3   97.0 +15.7  -0.4 250.00 4.0
 6230 +17.6 4.4 101  90    00   rich +24.7   98.9 +15.8  -0.4 250.00 4.0
 6277 +17.4 4.4 100  90    00   rich +27.5   92.9 +15.9  -0.5 250.00 4.0
 6361 +17.8 4.4 101 100    00   rich +27.8   94.8 +16.5  -0.6 250.00 4.0
 6373 +17.2 4.4 100  90    00   rich +28.3   95.4 +16.7  -0.5 250.00 4.0
 6472 +17.2 4.4 101  90    00   rich +27.7   91.7 +16.8  -0.5 250.00 4.0
 6626 +17.0 4.4 100  90    00   rich +27.9   94.9 +16.9  -0.5 250.00 4.0
 6242 +13.9 4.1   0  00    00   rich +11.2   74.4 +19.0  -0.9 ECU.   3.6
 6071  +7.8 3.4   0  00    00   rich  +8.8   35.2 +19.0  -0.9 ECU.   2.9
 5659  +0.8 3.0   0  00    00   rich  +8.9   22.8 +19.0  -0.9 ECU.   2.6
 5282  -6.1 2.7   0  00    00   rich +10.8   17.2 +19.0  -0.9 ECU.   2.4
 4866 -10.2 2.6   0  00    00   rich +11.3   32.4 ECU.   -1.0 ECU.   2.2
 4547 -10.8 2.4   0  00    00   rich +11.0   32.4 ECU.   -1.0 ECU.   2.1
 4251 -10.8 2.2   0  00    00   22.4 +11.1   32.4 ECU.   -1.0 ECU.   1.5
 3987 -11.0 1.8   0  00    00   lean +11.1   32.4 ECU.   -1.0 ECU.   1.8
 3639 -11.0 2.0   0  00    00   24.5 +11.4   32.4 ECU.   -1.2 ECU.   1.6
 3404 -11.2 1.7   0  00    00   lean +11.5   32.4 ECU.   -1.3 ECU.   1.7
 3144 -11.2 1.7   0  00    00   lean +11.7   32.4 ECU.   -1.7 ECU.   1.7
Old Jul 21, 2004 | 02:48 PM
RoadSpike's Avatar
just a guess hear but maybe your knock isn't so much the timing and A/F ratio after when the knock occurs as it is so much as before it happens.
Try smoothing out your timming curve from like two steps ahead of the knock where its at 60 percent load and up.
It could be the time its taking to adjust to those new settings and knocking just as it gets there.
And i mean your iginition timming btw.
On these lines
Set the first one to mod the timing back a couple of degrees maybe +18.0 and see if it helps you out. I'm figuring its between the points is your real problem.
Old Jul 21, 2004 | 03:41 PM
platypus's Avatar
Car Info: dangerous with a wrench
From the log, I'd suspect that the 19-20 timing advance on the several lines before the knock is the real culprit. Dial that back a few degrees and see if that doesn't solve the issue.
Old Jul 21, 2004 | 05:01 PM
mmboost's Avatar
But look at those load points, on those several lines previous. The +20deg is at 10%@5000k. The next entry is the +19deg 60%@5000k. It look like I mashed the throttle. With the piece of map below you can see how the curve shoots from blue, to green, to red. Pull timing all the way back to the 10% column? Take the entire curve and pull it "down" to higher RPMs?
Code:
x10     0%      10%      20%      30%      40%      50%      60%      70%      80%      90%
425 [-100]     [19]     [18]     [18]     [18]     [17]     [15]     [14]     [13]     [13]
450 [-100]     [19]     [19]     [19]     [19]     [18]     [15]     [14]     [13]     [13]
475 [-100]     [20]     [20]     [20]     [20]     [19]     [17]     [16]     [14]     [13]
500   [19]     [20]     [20]     [20]     [20]     [19]     [19]     [18]     [14]     [13]
525   [19]     [20]     [20]     [20]     [20]     [19]     [19]     [18]     [14]     [13]
Also note the fuel map, from -1.5 to 0. between 10@4750 and 90@5000. Its going from a leaning trend to getting squirted.
Code:
425   [-1]   [-0.3]   [-0.3]   [-0.1]    [0.2]    [0.3]    [0.5]    [0.6]    [0.6]      [1]      [1]
450   [-1]   [-0.8]   [-0.8]   [-0.6]   [-0.3]    [0.2]      [0]    [0.4]    [0.3]    [0.6]    [0.5]
475   [-1]   [-1.1]   [-1.1]   [-0.9]   [-0.4]   [-0.1]   [-0.3]      [0]      [0]    [0.5]    [0.4]
500 [-0.9]   [-1.5]   [-1.5]   [-1.2]   [-0.2]   [-0.1]   [-0.7]   [-0.5]   [-0.2]      [0]      [0]
525 [-0.9]   [-1.9]   [-1.9]   [-1.2]   [-0.2]   [-0.5]   [-0.9]   [-0.9]   [-0.6]   [-0.2]   [-0.3]
Seem like there's just a drastic change all around going on.
jason
tkarabian
Mar 18, 2006 02:16 PM
Matth3w
Sep 8, 2005 07:28 AM
ryball
Jun 19, 2005 04:03 PM
