can tuning fix all cel?
Old Aug 20, 2007 | 02:19 AM
minisiu's Avatar
i hear some cel cause by replace a lighter fly wheel or some of them cause by MAF by replacing a intake my qustion is can tuning the ecu like utec, AP, reflash....... fix the cel propblem?
also if the car need to go to emission, does it need to cel free ( no cel) b4 i take it to emission ( state IL)
Old Aug 20, 2007 | 08:19 AM
you can turn the CEL fix on but it wont fix the cause
it reads misfire if you have too light of a flywheel / crank pulley combo
i dunno about IL emissions but california yes
Old Oct 26, 2007 | 03:40 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
first off to pass emissions test the CEL can not be on if it is they fail you right away
if your getting MAF faults its probably the oil from your aftermarket airfilter getting on the sensor or excessive turbulance in the intake pipe, only cobb intakes cure the turbulance problem, but normally the turbulance only causes driveability issues (flat spot in throttle) not CEL codes.
EQ Tuning
Nov 2, 2017 05:05 PM
tommysyko
Mar 16, 2006 01:47 AM
esracer
Mar 16, 2004 11:56 AM
mrtrex
Vendor Group Buys/Specials
Dec 23, 2002 05:50 PM
