-   Engine Management (https://www.i-club.com/forums/engine-management-66/)
-   -   A/C spray sound? (https://www.i-club.com/forums/engine-management-66/c-spray-sound-250559/)
vonburgundy Apr 19, 2013 09:05 PM
A/C spray sound?
Do any of you guys experience a loud patterned spray sound when you turn on the a/c? I own a 2005 sedan and I hear this aggressive spray sound in the cab that comes on from the engine. I decided to keep the car running with the a/c and pop the hood to see where the sound was coming from, and I found that a fan near the alternator, (probably the a/c fan, I don't know a lot about cars) stops spinning after a period of time and that spray sound creates a kind of boost for the fan to start up again. Is this normal? I feel like there may be a fault somewhere..
xhengmanx Apr 19, 2013 10:02 PM
that is the a/c compressor fan kicking on when the a/c is turned on. It is normal, but you should check to make sure you have the proper amount of freon in the car.
vonburgundy Apr 20, 2013 09:18 AM
[QUOTE="xhengmanx;3386996"]that is the a/c compressor fan kicking on when the a/c is turned on. It is normal, but you should check to make sure you have the proper amount of freon in the car.[/QUOTE]
How do I know if I have the proper amount of freon?
