Burn UP My Turbo?
Old Jun 13, 2003 | 09:33 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
There is no warm up procedure or cool down procedure, PERIOD.
If car's were manufactured with this in mind, it would have been stated in your manual. Cars for the american market, sadly are built for idiots. We're too content with low NVH, comfy seats, soft suspensions, and good gas mileage.... If we now had to wait a few minuted to bring the engine up to operating temps, or had to wait to cool down the engine, no one would buy a subaru in america.
Old Jun 16, 2003 | 11:15 AM
teiva-boy's Avatar
Originally posted by shark80
I disagree.
The heat generated through the turbo is intense. (check out web sites for building a jet engine... they use old turbos and they turn red). If you were to just shut the car off, therefore stopping the lubrication flow, the hot parts would sit still and bake... which is not good for the bearings. A friend of mine drives an Audi and I have seen his turbo glow red hot after some heavy driving.
Most people I know let their cars and trucks with turbos run for 3-5 minutes after trips of 20 minutes or longer.
http://www.junkyardjet.com/turbinefaq.html see here for the jet engine.
Wrong. The WRX turbo is oil and water cooled. Coolant still flows through the turbo after you shut down the car. It will not "sit still and bake," per say.
If Subaru felt the turbo would need to run after shutdown, it would have made proviions for it. Who are you to say that Subaru is wrong?
Now go to a larger turbo, then I will change my story. But stock for stock even on mild boost, your just fine without it. But if you feel the need for $100 in protection, more power to you. Better safe then sorry right?
Old Jun 16, 2003 | 12:18 PM
teiva-boy's Avatar
It's cool.
The subaru coolant system works off of pressure generated from the heat of the turbo. That is what moves coolant in and out of the turbo after you shut it down.
Old Jun 17, 2003 | 11:13 AM
RunRedLights's Avatar
OK, so now I have a question..its totally off topic from the initial thread but everytime I post it no one responds and you guys seem to know what your talkin about. I just finished my exterior/handling mods and im now starting to do engine upgrades. I bought a VS0, defi gauges (boost, oil, egt), greddy catback, and im currently trying to get my hands on a vf30. I just wanted to know what boost levels to set my car at. I think (not sure) the VSO tunes the chip for 15.5+/- but should I up the boost since im getting a vf30? I read on some post that different gears have diff. boost levels, i wanted to know how you set that. Im having a friend install all my stuff and he has alot of knowledge on subaru components but I just wanted to know what the safe boost levels would be. I want my car to GO...but its a daily driver car also. By the way, my gauges are in SI units so that should be a pain also...
Old Jun 17, 2003 | 01:50 PM
nypatrick's Avatar
Car Info: 2002 WRX wagon
When I checked with the service manager at the dealer where I bought my 02 WRX I was told no cool down needed. But, I am sure also meant no "hot laps" before shut off. A friend who had a little 3-cyl suzuki with a turb. advices a minute of two of cool down. My tech for my other cars also said: coast along for a 1.4 mile or so before shut off. You pays your money........
Old Jun 18, 2003 | 12:38 PM
Ash's Avatar
Ash
Car Info: 02 WRX wgn full STI swap
well... hmmm....
At first I thought you guys were a little off about the cool down thing...
After searching through the manual, I found nothing about idleing the engine for any time before shutting it off... It say not to shut if off unless it's idleing, but that's as close as it got.
My 92 MR2 turbo manual specifically said to idle the engine for 60-120sec after lots of uphill driving or a "spirited" run. Most MR2 turbos start to die after about 70,000 miles (seeping oil and lower boost) unless better taken care of. My car was driven REALLY hard for 110k and the turbo still topped off the boost gauge in stock trim. I was always convinced that it was because I religously cooled it down by letting it idle for a minute or two before turning it off.
As for the WRX. I can tell you this:
I drive up a local hwy at night very often. 8 miles and a 2000ft climb with lots of tight corners. Whenever I get to the parking lot I pop the hood and watch my turbo glow RED hot.
-Turn the car off right away and the turbo stays red for a long time.
-Leave the car idle and the turbo cools to a nice subbtle burgundy grey in about three to four minutes...
I will continue to let my car idle for a few minutes after anything more than mild driving.
Ash
