Bov?
Old Aug 29, 2004 | 07:02 PM
mmboost's Avatar
you're modifying your air and fuel delivery systems if you are not getting a BOV that meets the same specs as the stock one. I'd say its a viable reason for a dealership service writer to complain.
you should just do what I did, take out all your cats, get an 100% non-return BOV and blow flames at the people behind you.
jason
Old Aug 30, 2004 | 12:29 AM
kettsupp's Avatar
why? isn't recirculation better than vta
Old Sep 1, 2004 | 11:56 PM
mmboost's Avatar
Originally Posted by SuicidalLabRat
A Bypass valve should 'recirculate';
SLR-
I wouldn't make it sound like such a blanket truth.
Being that our cars' fuel delivery is based on MAF readings, if you unexpectedly loose a ton of air you're going to have too much fuel. MAF is read before the compressor. The BOV dumps afterwards. Its not hard to see that this is a bad combo.
Admittedly right now I have such a bad combo. When I'm in a turn and I've come in a bit to hot and I want to squeeze off the gas, the BOV dumps and I bog. This jerks the car making for a very unsafe turn. I need an aftermarket BOV still because my other one is old (and already questionable) and I run ~17psi now with a vf34. I'll be looking into something that is atleast a variable or 50% return.
jason
ViVaSuBy
Sep 26, 2007 03:30 PM
subiedave
15
Oct 20, 2005 07:56 AM
Kuonji
Oct 18, 2003 12:48 PM
Scooby42
Wanted
Sep 21, 2003 06:20 AM
jiveturkey
Jun 1, 2003 07:12 PM
