Argh! Need help! (UTEC and knocking)
Old Jul 17, 2003 | 02:31 PM
FinalBean's Avatar
Car Info: 2008 DGM WRX STI
So I have a full catless turboback, catless uppipe and Samco IC hoses. I've been having serious knocking issues with the new stage2 maps, even when I added .2 to fuel and subtracted 2 from timing across the board. This has happened across different tanks of Chevron 91 octane too. So I reset my ecu yesterday, closed the ABC, and set it to a blank map (ECU across the board on every map). There was STILL knocking, especially in 4th and 5th gear at around 3-4k rpms, sometimes at only 7-10psi! Has this ever happened to anyone? Is my knock sensor going haywire, or is my engine beat, or have I had astronomically bad luck with gas? Any help would be appreciated.
-John
Old Jul 20, 2003 | 07:21 PM
jrauck's Avatar
Car Info: Sil. WRX
use 93 instead of 91 and then try to make changes.........
Old Jul 22, 2003 | 11:43 AM
international B's Avatar
Chewwwwy
just pull the timing 4 degrees, and leave the fuel the same...
make sure you have a good map in there... i would recomend using a turbo xs map, with timing pulled back 4 degrees. if that dosent work, make sure all the mods for the map are the same as your mods. if that still dosent work, you might have a bad knock sensor...
Z1 Performance
Vendor Group Buys/Specials
Jun 2, 2004 12:52 PM
spankmeplz700
13
May 2, 2004 04:22 PM
SpeedRevelation
Apr 12, 2004 01:22 AM
bclee
Nov 21, 2003 10:03 AM
