-   Engine Management (https://www.i-club.com/forums/engine-management-66/)
-   -   AP not flashing... (https://www.i-club.com/forums/engine-management-66/ap-not-flashing-244502/)
esousa22 Sep 5, 2012 07:59 PM
AP not flashing...
So I just bought a V1 accessport for my 04 wrx today and plugged te test connector together and the "initialization" connector, plugged the AP in, it says choose a new map to flash to my car so I choose the stage 2 map and it says turn the car fully off then on. I do that and then hit select right away to start the process and it says initializing for 10-20 seconds and then says turn the car fully off and back on again...
Anybody know whats going on? My ecu has already been flashed with a stage 2 tune with ecuflash, is that my problem? Do I have to put the stock map back on with ecuflash to be able to use the accessport?
Any help would be appreciated
Blazingbuda40 Sep 5, 2012 08:30 PM
I'm totally guessing but I think the othe stage 2 tune is conflicting with the accessport
esousa22 Sep 6, 2012 08:50 AM
bump for some info
Brfatal Sep 6, 2012 09:17 AM
[QUOTE=Blazingbuda40;3288369]I'm totally guessing but I think the othe stage 2 tune is conflicting with the accessport[/QUOTE]
Nope. The AP will flash over whatever is on the ECU.
esousa22 Sep 6, 2012 10:06 AM
[QUOTE=Brfatal;3288542]Nope. The AP will flash over whatever is on the ECU.[/QUOTE]
Whats a stock "SOA" map?
What if its a "locked" flash? I don't remember where I heard that there are tuners that lock their maps so another tuner cant retune their maps, not sure if that would be a problem. I did a little research after posting and found this
[URL="https://forums.cobbtuning.com/forums/showthread.php?35932-AP-V1-in-2002-WRX/page3"]https://forums.cobbtuning.com/forums/showthread.php?35932-AP-V1-in-2002-WRX/page3[/URL]
[quote]Someone may have monkeyed with the ECU and that is why the AP is not recognizing the ECU. The AP is looking for a stock SOA map...I'm almost at a loss.
You've done everything right, the AP is trying to marry but then the error hits...makes me think the ecu has been flashed.
I've been looking at my AP manual and it says..."turn ign key to the ON position...Within 5 seconds of turning the ign on you need to press the SELECT button to begin the initialization process. If you wait too long, the procedure will time out and you will be forced to try again."
[/quote]
[quote]Ok that's about all I can do for you...I think your ECU has a flash on it...[/quote]
Brfatal Sep 6, 2012 10:52 AM
The AP is not looking for a "stock" SoA map. It will flash over whatever is there. I know this 1st hand.
esousa22 Sep 6, 2012 10:55 AM
[QUOTE=Brfatal;3288591]The AP is not looking for a "stock" SoA map. It will flash over whatever is there. I know this 1st hand.[/QUOTE]
Cool, thanks. What does SoA stand for? I halfa$$ searched and didn't find anything. Any idea what the issue could be? I was able to flash the car before with a tatrix and ECUflash, why won't it work with the AP?
Brfatal Sep 6, 2012 11:05 AM
Subaru of America. They were saying it was looking for a factory Subaru map. I've had an OS tune flashed over with 2 different APs on 3 separate occasions. I would call Cobb and ask. It's a V1 though, so if something is wrong with it they've already technically dropped support for it.
esousa22 Sep 6, 2012 11:19 AM
ahhhhhh okayyy. I will give them a call then, thanks! :thumb:
Of course I'm still in for some input
esousa22 Sep 8, 2012 10:58 AM
bump! I haven't called cobb yet
David William Nov 13, 2012 04:54 AM
Even my nissan micra has got similar problem...suggestion regarding this prob...
sorry to hear that...I'm totally guessing but I think the other stage 2 tune is conflicting with the access port.. its really irritating when we are facing such problem... Even i have nissan micra and have to face similar sort of situation.. I did a little research after reading your post.. for all my car related problems i visit this below link... i am sharing with you this link.. it might solve your problem...
[url=http://www.winchbooks.com.au/nissan-micra-workshop-service-repair-manual/]nissan micra service[/url]
esousa22 Nov 13, 2012 12:40 PM
The problem was my current stage 2 map. I talked to cobb and they said either the unit is damaged or my current map is conflicting with the AP. I since resolved the issue by just selling the AP. The guy I sold it to said it worked find, he married it to his car and is now running stage 2. : banana : I just forgot to update the thread
Brfatal Nov 13, 2012 02:02 PM
He's a spammer esousa.
esousa22 Nov 13, 2012 07:11 PM
I figured, saw the one post and didnt click the link. Just updated the thread, thanks though fatal
