Any running Cobb AP & EBC together? Help!
Old Jun 16, 2007 | 07:54 PM
2004jmwrx's Avatar
Car Info: 04 Subaru WRX
Hi everyone, I am driving 04 WRX manual. I have just installed Cobb AP stage 2. My Greddy Profec e-01 installed almost a year. After I installed AP, I put the stock boost controller back because most people did in Cobb forum. But I found out the turbo spool up a way slower than EBC and not easy to meet target boost. I am wondering back to EBC soon. My question is "Any problem if I use EBC over the stock on my Cobb stage 2 setting.
Any member running AP and EBC together? Please help me with good subjection or idea, please? Thanks!
Old Jun 17, 2007 | 07:35 AM
03_Impreza_Al's Avatar
Turn the WG arm clockwise till you hit target boost.
Old Jun 17, 2007 | 09:08 AM
2004jmwrx's Avatar
If I turn it to meet target boost, is it spool up faster. Can you show me how to turn WG arm with diagrams or pictures? Thanks!
Old Jun 17, 2007 | 09:16 AM
take off the heatshield. You'll see a little clip at the end of the arm. Push in the arm and the clip will loosen then you can take it off I use long nose pliers (DO NOT LOSE THIS). Then just pop out the arm. Then make one full rotation. Place the arm back push it in so its easy to put the clip back in. Then pull the arm out so it fits snug on the clip. Test to see if you are hitting target boost and adjust if u need to. Don't forget to put the heatshield back on. Good luck dude.
***TAKEN FROM SCOOBYMODS.COM***
I'd recommend doing your pulls in 3rd in 4th to see if you are hitting your target.
Old Jun 20, 2007 | 10:55 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
You should not run an EBC or MBC with an AP unless you get a custom tuned map with the aftermarket boost control. That being said, the stock boost control will never provide the same response as a good EBC or MBC.
bmxhotsauce
30
Mar 30, 2013 02:37 PM
2004jmwrx
May 27, 2007 08:21 PM
iNfEk
Sep 4, 2004 09:37 PM
TDI_Savva
Apr 19, 2004 03:56 AM
Top
