For all AccessECU StreetTUNER & ProTUNER users...
Old Jan 21, 2006 | 02:59 PM
Christian.'s Avatar
I wanted to make sure that all of you were aware of the various plug-ins we have developed for various external datalogging/WBO2 devices. Here is a link to the latest .dll files and notes = http://www.wrxforum.com/cgi-bin/ulti...;f=12;t=000289
Please follow the directions Jon has written for using these files.
Take care,
Christian.
Old Jan 21, 2006 | 04:53 PM
Wingless Wonder's Avatar
Copied and pasted from Christian's linked .url:
Originally posted by Jon Pomrenke:
Below you will find links to the latest versions of the external interface files.
First of all, install and configure your external device and verify it works outside of StreetTUNER. If it doesn't work outside of StreetTUNER then it can't work inside of StreetTUNER.
Second, you must install the external interface. To "install" an interface, you must download the file and copy it into the Plugins folder located inside your StreetTUNER installation folder. Once the file has been copied, restart the software and go to "Configure Options". Select the interface you wish to configure and choose the COM port where it can be found. Connect as usual, go to "Configure Options" again and select the dashboard/logging options (typically prefixed with the name of the interface) you wish to see.
Innovate Motorsports LM-1/LC-1 interface.
Last updated: 2005-07-05
PLX Devices Inc. M-300 USB interface
Last updated: 2005-11-15
PLX Devices Inc. R-300/500 interface.
PLX Devices Inc. R-300/500 notes.
Last updated: 2006-01-20
Zeitronix Zt-2 interface
Last updated: 2005-06-16
NOTE: The interfaces listed above are dynamic link libraries created to work with the Microsoft Windows-based AccessECU StreetTUNER and ProTUNER software.
Thank you, Christian, for providing the .url with the information.
Christian.
Aug 29, 2006 09:12 PM
MoDrift
Oct 29, 2005 09:27 PM
EQ Tuning
Jul 25, 2005 12:15 AM
