Ver. 6 STI RA gearsets in stock! ACT and Exedy Clutch combos!
Old Jan 30, 2006 | 06:24 PM
gruppe-s's Avatar
For the first time every in many many moons, we have STi Ver. 6 RA gear sets in stock and ready to ship.
Version 6 STI RA (Special Edition) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- Stronger than stock WRX gears
- 1mm thicker gears
- Cryotreated for added durability
- Replace gears 1-4 (shorter ratios)
- Retains stock 4th and 5th gear ratios
- Better accelleration, same cruising fuel mileage
Version 6 STI RA (Normal) Gearsets w/ Bearings and Synchros- Cryo Treated - $1909 shipped
- 1mm thicker gears
- Replace all gears (shorter ratios)
- Ideal for track
JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box; the way it was designed to be. This conversion will be particularly useful for those of you who regularly track or drag race your car. As I'm sure you've noticed, their is a large space in gear ratios between 4th and 5th gears on the USDM 6spd. This oftentimes causes a grinding when shifting from 4 to 5 quickly because the synchros cannot catch up quickly enough to compensate for the large difference between gear ratios. Professional installation is recommended.
- Excellent upgrade for motorsports guys
- Better accelleration in 5th and 6th gear.
- Eliminates grinding when shifting up from 4th to 5th gear
- Restores 6 spd. to intended gearing
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
$319 Shipped for 5/6th Gear Conversion
$769 for rebuild w/ 5/6th Gear Conversion
Genuine Subaru Synchro & Bearing Kit for 6 Speed Manual Transmission (13 pcs) - 04+ STi
We have packaged together the most commonly damaged synchros and bearings for the Subaru STI 6-speed transmission. In all likelihood, if a transmission rebuild is necessary, these synchros and bearings also need to be replaced. Replacing these synchros and bearings can also cure many "mystery" gear box issues such as, "why does my tranny always grind going into 3rd gear," or "how come I sometimes can't shift down into 2nd gear." These are in stock and ready to ship. You can also send us your 6spd. to be rebuilt with these.
- Should be replaced when rebuilding your tranny
- Cures many transmission gremlins
$419 Shipped for Synchro and Bearing Kit
$869 for rebuild w/ new Bearing and Synchro Kit
Save money if you do both at the same time!
$719 Shipped for Synchro and Bearing kit, and 5/6th Spd. Conversion
$1149 for rebuild w/ new Bearing and Synchro Kit, and 5/6th Spd. Conversion
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped
These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
Old Jan 30, 2006 | 06:25 PM
gruppe-s's Avatar
1) Exedy Organic Clutch Kit and Steetlite Flywheel - 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
$750 Shipped!!!
$1175 Installed!!!
2) Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2655 lbs/ft.
$PM FOR BEST PRICE!!!
3) Exedy Twin Plate Clutch/Flywheel Kit - 02+ WRX
-Clamp Load: 2205 lbs/ft.
4) Exedy Organic Clutch Kit and Steetlite Flywheel - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
5) Exedy Hyper Single Clutch/Flywheel Kit - 04+ STi
6) Exedy Twin-Plate Clutch/Flywheel Kit - 04+ STi
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Old Jan 30, 2006 | 06:26 PM
gruppe-s's Avatar
1) ACT HD Street Disc Kit and Steetlite Flywheel - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649 Shipped!!!
$1100 Installed!!!
2) ACT HD Street Disc Kit and Prolite Flywheel - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped!!!
$1119 Installed!!!
3) ACT HD Street Disc Kit and Steetlite Flywheel - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
4) ACT HD Street Disc Kit and Prolite Flywheel - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
And for the hardcore guys out there:
5) ACT HD 6 Pad Race Kit and Prolite Flywheel - 02+ WRX
-Torque Capacity: 527 lbs/ft.
$699 Shipped!!!
$1119 Installed!!!
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Old Feb 1, 2006 | 07:57 PM
myroncuz's Avatar
gearsets are in stock?
Old Feb 2, 2006 | 10:25 AM
Shane Morris's Avatar
Car Info: 05 wrx
I just called and you said they are not in stock. Why do you advertise that they are in stock, if they are actually out of stock when the customer (myself) calls? Just wondering.
Old Feb 2, 2006 | 03:41 PM
gruppe-s's Avatar
The gearsets were in stock when this post was made. They are no longer in stock as of yesterday. I apologize for the confusion. A new post will be made to reflect this.
Thanks,
Geoff
Speed Element
Engine and Drivetrain
Dec 6, 2007 05:24 PM
WorldONE
Apr 13, 2007 06:21 PM
gruppe-s
May 1, 2006 07:42 PM
gruppe-s
Apr 25, 2006 11:38 AM
gruppe-s
Jan 30, 2006 06:30 PM
