Pink Springs and Upper Mount Specials! Whiteline, Zeal, Tein, Endless, etc!
Old Jun 15, 2006 | 04:49 PM
gruppe-s's Avatar
Cusco:
Cusco Pillowball Upper Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi - $639 shipped!!!
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front or Rear
STi:
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi - $639 shipped!!!
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
Whiteline:
Strutbars:
02+ WRX /04+ STi Front - $135 Shipped!!!
02+ WRX /04+ STi Rear - $145 Shipped!!!
02+ WRX Wagon Rear with Quick Release - $155 Shipped!!!
02+ WRX /04+ STi Front and Rear Combo - $270 Shipped!!!
Swaybars:
22mm Front - 02+ WRX - $125 Shipped!!!
22mm Adjustable Front - 02+ WRX - $155 Shipped!!!
22mm Front, Wagon ONLY - 02+ WRX - $125 Shipped!!!
22mm Adjustable Rear - 02+ WRX - $155 Shipped!!!
22mm Front - 04+ STi - $125 Shipped!!!
24mm Adjustable Front - 04+ STi - $175 Shipped!!!
27 / 29mm Adjustable Front - 04+ STi - $225 Shipped!!!
24mm Adjustable Rear - 04+ STi - $175 Shipped!!!
Endlinks:
Bushing Type 02+ WRX Front /04+ STi Front or Rear - $109 Shipped!!!
Bushing Type 02+ WRX Rear - $109 Shipped!!!
Bushing Type 02+ WRX /04+ STi Front and Rear Combo- $210 Shipped!!!
Spherical Type 02+ WRX Front /04+ STi Front or Rear - $109 Shipped!!!
Spherical Type 02+ WRX Rear - $109 Shipped!!!
Spherical Type 02+ WRX /04+ STi Front and Rear Combo- $210 Shipped!!!
Lateral Links:
Whiteline Lateral Link Set for 02+ WRX - $345 Shipped!!!
Anti Lift Kit:
Whiteline Anti Lift Kit for 02+ WRX / 05+ STi - $205 Shipped!!!
These ALKs are available in 3 levels: Race (extra cost), Medium, and Comfort.
Steering Bushings:
Whiteline Steering Rack Bushings:
02-04 WRX /04 STi ONLY - $30 Shipped!!!
05+ WRX / STi ONLY - $57 Shipped!!!
Whiteline Rear Subframe Bushings for 02+ WRX / 04+ STi - $31 Shipped!!!
More Whiteline products available through our site:
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
*CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)
Old Jun 15, 2006 | 04:55 PM
gruppe-s's Avatar
Zeal:
Key Features:
-Comes standard with X Coil springs. X coil springs utilize thinner spring wire and less coils meaning that they are substantially lighter than competitors' springs while also retaining more linear spring rates.
-Upper Mounts: A lightweight, aluminum rigid upper mount with rubber bushing decreases noise levels and eliminates vibration through absorption. Strut type uses pillow ball upper mounts for camber adjustability front and rear and direct feel of suspension motion while helping to decrease piston rod tension.
-Shock Absorber: The greatest merit of our lightweight, monotube type shock absorber is that it is produced with a very large piston for direct feeling and steering response. Ride quality and sensitivity is increased while also improving cooling characteristics of the damper. All systems are professionally race-tested and developed in Japan by certified engineers.
- Height Adjustable Lower Bracket: height can be adjusted independently of spring preload.
Zeal XS Coilovers
$2470 Shipped - 02+WRX/04 STi or 05+ STi
*Function-Xs includes 6-Way Dampening Adjustability
*Standard Spring Rate: FT: 8kg/mm RR: 6kg/mm
*Custom spring rates available at no additional charge
Zeal XS Coilovers
$2850 Shipped - 02+WRX/04 STi or 05+ STi
*The Function X is similar to the Function XS but features more aggressive valving and is 30 way damping adjustable.
*Standard Spring Rate: FT: 10kg/mm RR: 8kg/mm
*Custom spring rates available at no additional cost.
Tein:
Tein Flex Coilovers
$1529 Shipped
$1859 Shipped w/ EDFC
*Currently in stock for 02+ WRX / 04 STi ONLY
*Independently height adjustable
*16 way dampening adjutable
*EDFC compatible
*Pillowball mounts all 4 corners (camber adjustable in the front)
*10 KG F / 8 KG R spring rates
Tein Super Street Coilovers w/ Pillowball Upper Mounts
$1339 Shipped
*Currently in stock for 02+ WRX / 05+ STi
*5 KG F / 5 KG R spring rates
Tein Basic Coilovers
$899 Shipped
*Currently in stock for 06+ STi
*6 KG F / 5 KG R spring rates
Tein S. Tech Springs
$189 Shipped
*Currently in stock for 02+ WRX / 04 STi only
*Height: -2.0" F/ .7" R 02-03 WRX; -2.2 F/ -1.7 R 04+ WRX; -1.6" F/ .9" R 04 STi
*Spring Rates: 3.9 kg F/ 2.8 kg R 02-03 WRX; 4.5 kg F/ 3.9 kg R 04 WRX / 04 STi
Helix:
Helix DNA Coilovers - 02+WRX/04 STi or 05+ STi Fitment! -
$999 Shipped!!!
- 8/6 kg/mm spring rates.
- Exclusively matched valving
- Independently height adjustable lower bracket
- 16 way dampening adjustable
- Light aluminum Shock Body
- Camber Adjustable, Full Pillowballs in the Front
- Comparable to Tein Flex
- "EDFC" in the works
- Excellent balance between street and track coilver
- Fully rebuildable
- Custom spring rates available for additional cost
Both fitments available July 1st.
Helix Endlinks (Full Pillowball)
Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$99 shipped for WRX Wagon Front!!!
$99 shipped for WRX Rear!!!
$99 shipped for STi Rear!!!
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Old Jun 15, 2006 | 05:15 PM
gruppe-s's Avatar
Brakes:
Project Mu SCR Pro 2-piece Rotors for 04 or 05 STi -
Special introductory price of $675 Shipped!!!
-2-piece design allows aluminum hat for lightweight rotors.
-Full floating design allows expansion of rotor and hat at different rates to prevent pad coning.
-Slotted to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors.
-Vaned to promote cooling.
-Allows you to retain stock Brembo calipers
Porterfield R4-S Pads F, Project Mu SCR Pro Rotors F, Goodridge SS lines F+R: $1049 shipped!!!
Endless Vita Nouva – 02+ WRX/04+ STi, F/R
Vita Nuova is Endless' most popular, entry level compound for the everyday sports-minded, city driver concerned especially with safety. For the spirited driver, factory brake pads may feel stressful at times. If so, this compound will appeal to you. This pad focuses on safety and stopping power.
$99 shipped for F or R, $190 shipped for F and R!!!
Endless SSS Pads - 02+ WRX /04+ STi, F/R
These pads are an excellent choice for the agressive street driver. They are non-metalic so they are rotor friendly and dust is minimal. The SSS feature a high friction coefficient so they are suitable for short weekend track stints but are not applicable for heavy track use.
$152 shipped for F or R, $300 shipped for F and R!!!
Endless CC-A Pads - 02+ WRX/04+ STi, F/R
The emergence of heavier and more powerful vehicles has led to the development of the ultimate semi-metallic, street compound with impressive pedal feel and the lowest levels of disc rotor abrasion, noise, and dust levels amongst the CC line-up. Perfect within the street temperature and speed range with a high level of braking force and controllability.
Endless CC-X Pads - 02+ WRX/04+ STi, F/R
Proven to perform well on both street and track conditions, this original formula, ceramic carbon metal base compound has the ability to perform for a wider range of users. For the street where low temperatures are frequent, this pad performs well causing less damage than most semi-metallic pads. Usually, semi-metallic pads sacrifice initial response to perform better at higher temperatures, but the CC-X is able to do well at initial response as well. At higher temperatures, pedal feeling responds well while maintaining controllability with a stable coefficient of friction.
$250 shipped for F OR R, $435 shipped for F and R!!!
Porterfield R4-S Brake Pads (carbon kevlar), 04+ STi, F/R
These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material.
Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys.
$199 shipped for F, $269 shipped for F and R!!!
Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only
~Brembo Sport slotted brake rotors are for drivers who want to improve the
looks and performance of their vehicle's original braking system without
having to change additional brake components.
~Brembo Sport slotted and drilled brake rotors provide excellent stopping
power in everyday traffic, as well as high performance street and track
driving.
~Brembo Sport slotted brake rotors match the vehicle's original equipment
rotor's dimensions and are fully compatible with its hubs, brake calipers
and road wheels.
$394 shipped for F, $375 shipped for R!!!
OK, now for the packages:
04 STi Front:
1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!!
2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!!
3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!!
4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!!
Special Brake Packages for the WRX:
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
Old Jun 15, 2006 | 10:24 PM
bluewrx82's Avatar
pm'd ya, bump!
Old Jun 15, 2006 | 10:48 PM
gruppe-s's Avatar
Originally Posted by bluewrx82
pm'd ya, bump!
pm replied
Old Jun 16, 2006 | 12:27 AM
odzilla's Avatar
Car Info: subaru wrx wagon
PM sent.
Old Jun 16, 2006 | 10:56 PM
gruppe-s's Avatar
Originally Posted by odzilla
PM sent.
I believe you ordered with us today?
Old Jun 17, 2006 | 09:08 AM
bluewrx82's Avatar
purchased from the site, thanks again.
Old Jun 17, 2006 | 12:47 PM
gruppe-s's Avatar
Awesome! I will be sure our guys keep an eye out for it.
Cheers,
Mark
Old Jun 20, 2006 | 12:27 AM
TheScoobyMedic's Avatar
Car Info: 05 wrx
youre sellin the edfc with the tein flex... i thought it didnt fit on wrx's..i got an 05 wrx, will it fit?!?
Old Jun 20, 2006 | 11:53 AM
gruppe-s's Avatar
I am unaware of any compatability issues with the EDFC going onto a WRX, they should work for all 02+ Impreza's. You can find more information at http://www.tein.com
Cheers,
Mark
Old Jun 21, 2006 | 04:55 PM
Car Info: 05 wrx
Cheers,
Mark
have you guys installed the flex with edfc on the wrx? tein's homepage states on their product list's footnotes that there isn't enough hood clearance with the edfc
Old Jun 22, 2006 | 03:04 PM
gruppe-s's Avatar
That's very odd. We put those on WRXs all the time and they have absolutely no fitment issues. Additionally, there is no difference whatsoever between the STi and WRX in that respect. These will work on your car guaranteed.
Thanks,
Geoff
Old Jun 22, 2006 | 09:51 PM
Car Info: 05 wrx
thanks ! can you guys give me a quote of tein flex with efdc and install?
Old Jun 23, 2006 | 12:16 PM
gruppe-s's Avatar
Sure thing! PM sent.
-Geoff
GST Motorsports
Aug 28, 2008 11:53 AM
gruppe-s
Engine and Drivetrain
Jul 10, 2006 05:27 PM
gruppe-s
Jul 7, 2006 01:04 PM
gruppe-s
Jun 17, 2006 07:57 PM
gruppe-s
Jun 14, 2006 03:10 PM
