New Product! Grimmspeed External Wastegate up pipe kit! look inside!
Import Image and GrimmSpeed would like to introduce the Grimmspeed External Wastegate Up Pipe with 38mm flange kit to you!
WHAT IS IT?
An external wastegate allows the exhaust gases to be diverted prior to
entering the turbo. Dumping the exhaust gas prior to the turbo helps with boost control, maintains boost longer in the rpm range, and extends the life of your turbo. Our pipe is fully built stainless steel EWG Up pipe and stainless steel dump tube for turbo Subarus. Monster thick SS flanges that will not warp. We have added a flex section which extends the life of the product and will lead to less exhaust leaks
because the pipe can flex vs. warping the flanges in a non-flex setup(inturn creating leaks).
WHY DO YOU NEED IT?
Reason for switching to an EWG setup includes:
1. Quicker turbo spool by allowing the exhaust gas to exit pre-turbo. There is alot of turbulence in the stock turbo at the internal wastegate so by moving the wastegate out of the turbo you get rid of this nasty turbulence thus improving the effiecency of the turbo as well.
2. More efficient wastegate design that has a bigger diameter than stock allowing for the exhaust gas to be released quicker.
3.Hold peak boost longer. This allows you to run a lower peak boost and increase HP at the same time.
Much larger than the stock internal wastegate!
No more boost creep...EVER!
GAINS?
Users should expect gains in the 15-40hp range when tuned for the EWG setup.
Another unique aspect of our package is that we include a bracket that holds your stock internal wastegate shut. This is great because you will no longer have to weld your turbo door shut which means you have no chance for leaks and you can revert back to stock anytime you want with no hassle.
PACKAGE CONTENTS
EWG Up Pipe
Dump Tube
Area1320 Bracket to hold stock wastegate closed(no more welding!)
5 Studs for Up Pipe
2 Allen head bolts for dump tube>wastegate
INCLUDES IWG BRACKET!!
What does that mean!? you no longer have to weld your stock turbos and you can return it to stock much easier! Not only is this a great product, its an innovation on the current market.
Gladly bringing you new products!
Josh Nahm
www.importimageonline.com
239 540 6385
WHAT IS IT?
WHY DO YOU NEED IT?
GAINS?
PACKAGE CONTENTS
EWG Up Pipe
Dump Tube
5 Studs for Up Pipe
Josh Nahm
239 540 6385
nallen316s
Oct 6, 2014 11:54 AM
jankenpon
SoCal Classifieds
Dec 20, 2013 03:39 AM
jankenpon
Sep 24, 2012 10:12 AM
hey1230000
May 19, 2010 07:27 PM
xs_wrx
Feb 27, 2006 06:27 PM
