More Power for your Suby with Harman, Perrin, Invidia, GReddy, More more more!!
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
We carry pretty much everything Invidia! If you dont see it here PM or give us a call. We have Great Pricing on Everything!!
Non-Polished Catless Downpipe for 02-07 WRX/STI - $269 Shipped!!
Catted Downpipes for 08+ WRX/STI - $525 Shipped!!
Cattless Down Pipe (Divorced Waste Gate): 08+ WRX/STI - $300 Shipped!
Catless Down Pipe (Divorced Waste Gate): 02+ WRX/STI - $300 Shipped!
The Invidia Exhaust Down Pipe features a 1-piece design, eliminating the need for the stock catalytic converter. As with all other high-quality Invidia exhaust products, the Invidia Exhaust Down Pipe is constructed using top-quality SUS304 stainless steel, CNC-machined flanges, mandrel bent, and robot-TIG welding.
Each Invidia Exhaust Down Pipe comes with all necessary hardware, gasket and bolts The Invidia Exhaust Down Pipe can also be bolted up to any Invidia catback exhaust or stock catback exhaust unit.
N1 Catback Exhaust - 02+ WRX - $600 Shipped!
Engineered with advanced technology, Invidia uses computerized mandrel-bent to give the exhaust the straightest possible line from the cat-back to the tip with the least amount of bens, CNC machine flanges for strong solid support, and robot TIG weld for piping, performance mufflers, and tip to improved strength and durability.
Has a resonator, flex section, and comes with a removable inner silencer to reduce noise levels.
N1 Catback TITA Tip: 08+ WRX/STI - $600 Shipped!!
08-UP WRX/STI TITA. TIP N1 CAT-BACK. Piping Dia.: 76mm. Tip Dia.: 101mm
N1 Catback: 08+ WRX Hatchback - $600 Shipped!!
fully polished SUS 304 stainless steel. The flex joints are used to dampen the cat-back exhaust system from engine vibration. The exhaust features CNC machined flanges, robot TIG welded, and computerized mandrel-bent tubing for the straightest possible line and the lease amount of bends.
Tip Size: 101mm Pipe Size: 76mm. Will not work on WRX Sedan. Only for the Hatchback
N1 Racing Catback Exhaust - 02+ WRX/ STI - $530 Shipped!
Invidia Exhaust Systems are engineered to maximize horsepower and torque gains. It is constructed of SUS-304 fully polished stainless steel from the cat-back to the canister and features a 101mm tip.
This exhaust is designed to be as straight as possible for maximum power.
Q300 Catback: 08+ STI - $940 Shipped!
The Invidia STI Exhaust System is constructed with fully polished SUS 304 stainless steel. The flex joints are used to dampen the cat-back exhaust system from engine vibration. The exhaust features CNC machined flanges, robot TIG welded, and computerized mandrel-bent tubing for the straightest possible line and the lease amount of bends.
Features 4 Tips. Fits STI Only
Q300 Catback: 08+ WRX - $660 Shipped!
The Invidia WRX Exhaust System is constructed with fully polished SUS 304 stainless steel. The flex joints are used to dampen the cat-back exhaust system from engine vibration. The exhaust features CNC machined flanges, robot TIG welded, and computerized mandrel-bent tubing for the straightest possible line and the lease amount of bends.
Fits Hatchback only.
Call or Paypal sales@speedelement.com to order!!
*CA add 9.75% sales tax. AK and HI shipping is additional
Former Sponsor
We're happy to announce we carry Harman Motive Parts! High quality and dyno proven power!
Harman Motive CAI: 02-07 WRX/STI
The gains in power come from reduced restriction. Pulling cool air from the passenger fenderwell, the factory inlet scoop can be retained to provide more cool fresh air to the unit.
$230 Shipped!
Harman Motive CAI: 08+ WRX/STI
On Harman's Mustang dyno, a bone stock 2008 STI gained 12whp and 4lb/ft of torque peak with consistant gains of 12-15tq through the powerband.
$224 Shipped!!
Harman Motive Catback Exhaust: 08+ STI
This system is the perfect combination of tone, volume, and performance thanks to the resonator included in the mid-pipe. An exhaust you can enjoy everyday, whether it is the ride to work or a lap at the track.
$949 Shipped!
Harman Motive Catted Downpipe: 02-07 WRX/STI
The cast bellmouth design greatly reduces restriction at the turbo outlet and flows into 3" mandrel bent piping. An O2 bung is included on the bellmouth allowing for easy installation of an aftermarket AFR guage. Has a 200 cell metal-substrate high flow cat.
$479 Shipped!
Harman Motive Harman Motive EWG Uppipe: 02+ WRX/STI
The Harman Motive External Wastegate Uppipe (EWG) uses a Tial 44mm wastegate to control boost on even the most stuborn turbos. Using an EWG eliminates issues with boost creep and can even make more power than a traditional internally gated turbo.
$220 Shipped! Add your choice of Color TIAL 44mm Wastegate for $679 Shipped!
Harman Motive Turboback Exhaust: 08+ STI
Harman's top quality turboback exhaust has been proven to make an extra 10 peak horsepower and torque at wheels with no tuning. When pro-tuned to Stage 2 using the COBB AccessPORT, gains of 35 horsepower and 62lb/ft of torque were seen.
$1400 Shipped
Cobb AccessPORT 2.0. For 02-05 WRX, 04-07 STI, 06-07 WRX, 08+ WRX/STI
YOu know what it does. Its good.
$595 Shipped!
Call or Paypal sales@speedelement.com to order!![/b][/size]
ORDER Harman from our site directly!
$230 Shipped!
$224 Shipped!!
$949 Shipped!
$479 Shipped!
$1400 Shipped
$595 Shipped!
Former Sponsor
We have some great Perrin stuff in stock to boost your power and style all at once!
Perrin Cold Air Intake for 08+ WRX/STI!
This new 08 Intake was designed from the beginning to be a cold air intake. This provides much better more consistent HP and better drivability in all conditions.
$189 Shipped! Black in stock ready to ship!!
Perrin Down Pipe With High Flow Cat: 02-07 WRX/STI
Crafted from 3” 304 Stainless Steel, mandrel bent and TIG welded, this product insures smooth exhaust flow back to the catalyst. Making crisp boost and throttle response with a 300 cel cat.
$465 shipped! Available NOW!!!
Perrin Short Ram Intake System - 02+ WRX/ STI
Increase horsepower and style under your hood. With proper MAF sizing and new hard pipe (vs silicone) you will see consistent gains in horsepower, throttle response and fuel economy.
$170 shipped! Black in stock ready to ship!!
We have great pricing on ALL Perrin parts! PM us or check out our website for more!!! www.speedelement.com
GReddy Exhausts!
Greddy Comp TI-C Turbo-back Exhaust 02+ WRX/STI
Full on competition use only, GReddy now offers the "turbo-back" Comp Ti-C series. These are full race turbo applications which include a large racing dowpipe to replace the factory catalytic converters at the race track. The Comp Ti-C is for off-road use only.
$PM
Greddy Spectrum Elite Catback: 02-07 WRX/STI
Today’s sophisticated tuners want it all, and GReddy’s SE exhaust systems deliver the full spectrum of features desired in a street performance system. SE exhausts increase flow via tuned piping and larger, free-flowing mufflers for improved power, but provide discreet sound levels that won’t attract the wrong kind of attention.
$PM
Greddy Spectrum Elite Catback: 08+ STI
Same as above with Features: 70mm piping, sideways muffler, 4x 102mm tips
$PM!
Greddy TI-C Catback Exhaust 02+WRX/STI
GReddy Racing Ti-C Cat-back Exhausts combine the design, looks and flow of our Full Racing Titanium systems with the durability, deep sound, value and large application list of our other Stainless Steel street systems.
$PM
GReddy Exhausts!
$PM
$PM
$PM!
$PM
JM Auto Racing
Engine and Drivetrain
405
Dec 7, 2015 06:57 AM
shaggadelic
Nov 21, 2008 12:41 PM
DCH Motorsports
Apr 11, 2007 03:11 AM
335i, accessport, bellmouth, competition, downpipe, evox, exhaust, gains, greddy, harman, horsepower, hp, ti, tic, wrx
