GATES Subaru WRX & STI timing belts, timing belt kits, serpentine belts, seals
Old Feb 2, 2012 | 10:09 AM
CCC's Avatar
CCC
Former Sponsor
Car Info: 11 STI Sedan
Thumbs up GATES Subaru WRX & STI timing belts, timing belt kits, serpentine belts, seals
We have great deals on Gates maintenance parts for Subaru WRX & STI. We carry anything from seals to timing belt kits. Free expedited shipping is available on some parts. PM us for details and quotes.
PM us for a quote.
Gates Racing Micro-V Serpentine Belt Subaru WRX/STI (02-07) High Performance; 300% Stronger Than Stock; Blue; (A/C)
Gates Racing Micro-V Serpentine Belt Subaru WRX/STI (02-07) High Performance; 300% Stronger Than Stock; Blue; (Alternator & Power Steering)
Gates Racing Micro-V Serpentine Belt Subaru WRX/STI (08-up) High Performance; 300% Stronger Than Stock; Blue; (Alternator & Power Steering)
Gates Crankshaft Seal Subaru WRX/STI (02-07) Recommended to Install w/ Timinig Component Kits;
Gates Crankshaft Seal Subaru WRX/STI (08-up) Recommended to Install w/ Timinig Component Kits;
Gates Racing Timing Belt Subaru WRX/STI (02-07) High Performance; 300% Stronger Than Stock; Blue; 281 Teeth;
Gates Racing Timing Belt Subaru WRX/STI (08-up) High Performance; 300% Stronger Than Stock; Blue; 281 Teeth;
Gates Timing Belt Component Kit w/ Water Pump Subaru WRX 02-03 Includes 4x Pulleys (A, B & C), 1x Belt Tensioner (D), 1x Water Pump (E), 1x Timing Belt (F), Gaskets; 02-03 WRX
Gates Timing Belt Component Kit w/ Water Pump Subaru WRX 04 Includes 4x Pulleys (A, B & C), 1x Belt Tensioner (D), 1x Water Pump (E), 1x Timing Belt (F), Gaskets; 04 WRX
Gates Timing Belt Component Kit w/ Water Pump Subaru WRX/STI Includes 4x Pulleys (A, B & C), 1x Belt Tensioner (D), 1x Water Pump (E), 1x Timing Belt (F), Gaskets; 05-07 WRX; 04-07 STI
Gates Timing Belt Component Kit w/ Water Pump Subaru WRX/STI 08-10 Includes 4x Pulleys (A, B & C), 1x Belt Tensioner (D), 1x Water Pump (E), 1x Timing Belt (F), Gaskets; 08-10
Gates designed and produced the industry’s first V-belt and today is the world’s largest manufacturer of V-belts, timing belts and serpentine belts. Gates is the only manufacturer approved by virtually every major OEM to provide timing belts for new engines. This means that Gates is able to cover the aftermarket with timing belts that are OE-equivalent or better in service life and performance. Gates also has the largest selection of timing component kits for the aftermarket, with 75 percent of its kits being specified for import vehicles. Each kit for 1974 - 2007 model years contains all the parts needed for a timing belt system replacement: one or more timing belts, idlers and/or tensioners, and detailed instructions.
tbssubaru
Oct 29, 2011 12:09 PM
vsick
Apr 19, 2011 12:40 PM
sumgai
Dec 27, 2009 10:23 PM
andyhidley
Oct 27, 2005 07:11 AM
