Cosworth, APS, Manley, Cobb, Wiseco, BC, TurboXS and MORE! In stock at Slowboy.
Old Sep 1, 2008 | 09:59 AM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
SBR is your source for everything that is performance. This thread will be periodically updated, please stay tuned!
APS WRX-FMI/R6 BLACK X 16 / Silver X3
APS WRX-FMI/R4 BLACK X 6
APS WRX-CID/01 X 14
APS WRX-HFA/01 X 16
APS 590-047-000 X 17
APS 995-047-100 X 27
Oliver
om@slowboyracing.com
Old Sep 1, 2008 | 10:00 AM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
COBB 512100 X 1
COBB 912240 X 2
TXS WS-TBE-TI-RP
BC-0601
BC-0602
BC-0621
BC-0622
Old Sep 1, 2008 | 10:02 AM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Bearings SB0006 x 2
Head Gaskets 20000922 x 2
Head Gasket 20000919 x 4
Head Gasket 20000916 x 2
Valves 20000166 x 5
Pistons PA2667 x 1 set of 4
Pistons 20003674 x 1 set of 4
Rings 20001516 x 1
Rings 20001515 x 2
Rods 14416-4 x 2
Valves 11137-8 x 1
Valves 11138-8 x 1
WRX 309937I22 x 1
SUB 287661I12 x 2
K588M925 x 1
K598M995 x 2
Old Sep 1, 2008 | 10:03 AM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Things that may not be on the shelf but I can get in a timely manner
SUB209917I22 -Subaru 2.5L TURBO US STI 8.5:1 Pistons 99.5mm Bore
SUB209937I22 -Subaru 2.5L TURBO US STI 8.5:1 Pistons 100mm Bore
SUB193642I16 -WRX 92.5 Bore 23mmPin 30.3/1.193Comp Height -16 Dish Volume 333g 8.0 to 1 CR
SUB287642I12 -WRX 92.5 Bore 23mmPin 32.7/1.287Comp Height -12 Dish Volume 348g 8.0 to 1 CR
SUB287661I12 -WRX 93 Bore 23mmPin 32.7/1.287Comp Height -12 Dish Volume 353g 8.0 to 1 CR
WRX209917I22 -STI 99.5 Bore 23mmPin 30.7Comp Height -22cc Dish 399g 8.5 to 1 CR
WRX209937I22 -Mahle WRX209937I22 STI 100.00mm Bore 8.5:1 CR
CRS5137S3D -Subaru WRX EJ18/20/22 H-Beam Rods w/ 3/8" ARP 2000 Rod Bolts 5.137" Length
K579M925 -Subaru Stroker 92.5mm Bore For sleeved Block Only
K602M975 -Wiseco Subaru Hybrid EJ22 Block w/ EJ25 DOHC Crank/Rods
Old Sep 2, 2008 | 04:47 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Looking for an inexpensive upgrade for your TMIC?
I have 2 of these Bulls-Eye Power TMIC's available for sale
$495 shipped while supplies last!
Just like any of their products, BullsEye has already put this product thru the ringer and always provides the results! Inputing air into the top mount at 350 degrees farenheit, outlet temperatures came out at under 100 degrees! Keep in mind that ambient air temps are usually 85 degrees. If your wonder about pressure drop, this top mount does as well and better than some of the big name models out there. BullsEye's testing showed that only a 1/2 pound of pressure drop was detected at 18 psi and monitored at outlet at 17.5 psi!
Installing this top mount is pretty easy, the only thing that doesn't just bolt right on is that you may have to trim down the top mount rubber skirting because this unit is 4.5 inches thick! Everything else is a simple bolt on, if you have hand tools, you can be on the road in under an hour enjoying ice cold intake temps! This top mount makes an unbelieveable difference on stock turbo's and IHI bolts on's and also SBR's 16G and 20G turbocharger lines!
Old Sep 3, 2008 | 01:39 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Turbo XS external gate up pipes! $255 shipped!
Don't forget you'll need a 44mm Tial Wastegate!
PM me today!
Oliver
Old Sep 4, 2008 | 04:56 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
I have a couple GReddy Kevlar timing belts in stock for your EJ20 or EJ25 in stock.
$165 plus shipping for the couple I have left from the old pricing structure!
I also have 5 Power Enterprise kevlar timing belts!
Oliver
Old Sep 5, 2008 | 01:47 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
What I have for you today is a TurboXS Downpipe! $389 shipped
aaannndddd.............. TurboXS Short Ram Intake! $145 shipped
Oliver
Old Sep 8, 2008 | 05:02 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Need to keep your Air/Fuels in check?
I have your solution here.
Innovate DB Wideband Controller! available in RED or BLUE
This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
I also have the AEM UEGO available as well!
PM me for the BEST pricing available!
Oliver
Old Sep 9, 2008 | 04:29 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Keep your engine bay cool!
Check it out!
PM me with wishes!
Oliver
Old Sep 10, 2008 | 11:26 AM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
FREE shipping on all APS inlet pipes in stock!
At last a true high performance turbocharger inlet pipe that actually is a pipe! Due to the tight and complex space available under the stock inlet manifold, these pipes have traditionally been available only as an aftermarket silicon hose.
The APS Turbocharger Inlet Pipe however is precision manufactured in stainless steel and the thin wall tubing (when compared to silicon hoses) delivers the maximum possible internal sectional area for the highest turbocharger air flow. In addition, the strong pipe walls completely solves the problems of hose collapse when under suction at high air flow rates.
Old Sep 11, 2008 | 03:54 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Today, I'm not going to ask you to buy anything. I'm not going to drop my pants on pricing to compete. I AM going to show you what sets us at Slowboy Racing apart from the rest and why we pride ourselves on our engines. We take block cores from all over the country in all different conditions and machine them all IN HOUSE for your order. There is no outside work done here, from the time your engine arrives until the time it leaves anything that needs to be done is done here.
Sorry about this one being sideways.....
Thank you for looking and I hope that we can continue to serve you with quality engines and performance parts for years to come.
Oliver
Old Sep 12, 2008 | 12:37 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
So after my post yesterday braggin up my machine shop, I will put my money where my mouth is.
I have an EJ20 built and ready for you WRX! Internals are as follows:
Wiseco Pistons
Manley Rods
Cosworth Bearings
Now to the good stuff, Block pics!!! These I took this morning of the actual block being sold, as stated its a Manley/Wiseco EJ20 ready to go. This means it can ship the day you purchase. I only have ONE so dont delay!
(Link is for OEM EJ20, I don't have the Stage II on my site yet)
$2650 SHIPPED!!!! *NO CORE DUE*
Don't delay, at this price it won't last long!
Old Sep 15, 2008 | 02:31 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Blouch Dominator turbos available now.
shipped complete with coolant pipes and turbo oil drain tube installed and requires no modification to intake, exhaust, oil and coolant connections for installation
Please note these have a 5-7day build time, although the parts are in stock they are build to order.
Old Sep 16, 2008 | 12:17 PM
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Suffering from bad head? Give your head the performance it deserves with my "Good Head" package! Everything you need for that freshen up or complete build. Packages like this normally retail for $622 plus shipping I am offering it for a limited time for $600 SHIPPED!!! With this you get the following:
BC Stainless Valves (STD size or 1mm over)
Ferrea Valve Locks
Ferrea Valve Seals
Brian Crower Springs and Titanium Retainers
All shipped to your door for a limited price of $600 SHIPPED!!!
"Wow!" you may be telling yourself "Thats a good deal" BUT THATS NOT ALL!!
If you act now I will add in a pair of BC Cams for a special LOW LOW price.
$570 for EJ20
$635 for EJ25
Hurry, supplies are limited!
Oliver
