COBBAP & Helix 860cc ($999)*GREEN 8CM Combo! EJ25 LongBlocks*Greddy EVO 2*4-1 Headers
Old Oct 11, 2006 | 02:44 PM
gruppe-s's Avatar
Hey guys,
Cobb Access Port & Helix 860cc Injector Combo!
-Cobb AP for all STI's (EJ257 Turbo)
-Helix 860cc Injectors
-AP and Fuel system is capable of supporting 600+HP
-Cobb AP allows for proper function of larger injectors and changes to on-time
-Normal price is $1149, you are saving $150!!!
$999 Shipped!!!
The FP Green 8CM is back!!
FP GREEN 8CM, Helix 860cc Injectors, Cobb AP super Combo!
-FP Green with larger 8CM housing
-Walbro Fuel Pump
-Cobb AP 2004 STI only
$2499 Shipped!!
Add $50 for other cars
Add $100 for all other Drive-by-wire cars (2005+ STI, 2006 WRX)
Oil / Water lines additional $75
Hey guys we just got in a large shipment of JDM EJ25 engines! We have:
EJ25 Legacy Turbo Engine
-Virtually identical to USDM STI 2.5 Engine
-Less than 10,000km on engine
-Includes intake manifold, cam gears, sensors, water/oil pump, semi complete engine
-Leak down tested, At least 88% compression across all cylinders (factory is 80%+)
-Awesome for WRX engine swaps
$3499 + shipping
2006+ Plastic Coolant Reservoir
-Lighter plastic construction
-Used
$60 shipped
GREDDY EVO 2 Exhaust for STI
-High Flow Design
-50 State Legal
-Best balance between power and excessive noise!
$569 Shipped!!
Gruppe-S V2 Header
- 4-1 Investment Cast Collector
- NO low-end loss on 2.5 cars
- Gains of over 20 ft/lbs seen on modified STI's!
$399 Shipped!! (4 pcs left)
Go Fast Bits Pulley Kit (PS, alternator, crank, belts) - WRX 02-05 Red
-Kit includes lightweight crank, alternator, and power steering pulleys as well as new belts
-These are not underdrive pulleys so your car won't suffer from problems like the battery not recharging properly
-Lightening the reciprocating mass reduces load on the engine and thus frees up power and allows the engine to rev more freely
$225
Perrin Downpipe - WRX
-Mirror polished stainless steel
-Mandrel bent 3" piping
-utilizes a divorced wastegate design
$319
Please give me a call if you have any questions or would like to order. Thanks!!
Randy
randy@gruppe-s.com
510-783-5300
Old Oct 12, 2006 | 10:40 AM
gruppe-s's Avatar
bump
Old Oct 12, 2006 | 11:11 PM
v8killer2pt5's Avatar
Car Info: 2004 sti wrb
Is the plastic coolant reservoir still available???
Old Oct 13, 2006 | 11:47 AM
gruppe-s's Avatar
Hello,
The plastic reservoir is still available. Give us a call to order
-Randy
Old Oct 13, 2006 | 11:56 AM
Quick question evne though I am pretty sure the reservoir will work on a 04 Sti??
Old Oct 13, 2006 | 12:40 PM
gruppe-s's Avatar
Yes it will.
Old Oct 13, 2006 | 06:48 PM
gruppe-s's Avatar
Few More Parts to Add!
APS Flex Up-pipe!
-Flex Joint
-2 Ports for EGT, one for stock, one for Aftermarket Gauge
$199 shipped! 2 at this price!
GFB Stealth BOV
-Adjustable
-Able to Recirculate, Vent to Air, or 50/50
$289 shipped! 1 at this price!
Please give us a call if you would like to order.
Alex
(510) 783-5300
Old Oct 15, 2006 | 01:12 PM
WrbImprezaSti's Avatar
Car Info: WRX
how much for just COBB ap alone for 05 sti?
Old Oct 15, 2006 | 02:44 PM
4080wrx's Avatar
can i get a price quote on the below for an 05 sti minus the cobb ap because i already have one. also will i need to have street tuner for this or do you have a map already made for this combo? also please quote this for 96819. i look forward to doing business once again.
Jess
-Walbro Fuel Pump
$2499 Shipped!!
Old Oct 16, 2006 | 01:48 AM
mwahaworld's Avatar
Car Info: white WRX
will the green work with 2.0L without engine mod?
Old Oct 16, 2006 | 12:38 PM
gruppe-s's Avatar
Mwahaworld,
The green would work but its not recomended. You would have better luck with VF34 Turbo.
-Thanks
Old Oct 16, 2006 | 03:20 PM
VRT Gump's Avatar
If I already have the AP, what would the FP Green set up run?
Old Oct 16, 2006 | 04:23 PM
gruppe-s's Avatar
$1899.
Thanks,
Gary
Gruppe-S
xicema17x
Aug 10, 2008 01:56 PM
AdamBOMB_STi
Feb 7, 2007 01:47 PM
AdamBOMB_STi
Dec 21, 2006 08:42 AM
gruppe-s
Engine and Drivetrain
Oct 24, 2006 11:02 AM
