Aps Headers And Inlet’s In Stock!!!!
Old Mar 10, 2006 | 04:45 PM
RallySportDirect's Avatar
Former Sponsor
Car Info: GC,GF,GD,GR,GH
After a long trip from over seas the APS headers are finally here!!!! Get them before their gone!!! Only 995.00 SHIPPED
APS has configured a header that dose not lose 30 ft. lbs. of torque to gain 10 hp above 6000 rpm in fact it gains 30 ft. Lbs. at 3000 rpm and gains an additional 30 hp at 6000 rpm! Finally a header that works with out having to sacrifice bottom end power for top end power!
Also in stock are the APS Turbo inlet hose. This is the only metal hose on the market and comes with everything you need plus 2 different couplers to fit all turbos.
ONLY 275.00 SHIPPED
The APS Turbo inlet pipe is superior in that it is an stainless steel peice, not silicon. The stainless construction means that the pipe will not collapse under high boost. Also being steel, it allows for a much larger inner diameter for maximum airflow utilizing the thin-walled stainless steel.
Each APS Turbocharger Inlet Pipe is delivered with two entry pipe to turbocharger silicon coupling hoses.
One hose to suit the stock turbocharger and large 3" internal diameter hose matched to high performance turbochargers with a 3" inlet.
THESE WILL SELL OUT QUICK. GET THEM WHILE THEY LAST!!!
-Jason
Rallysport Direct.
www.rallysportdirect.com
801.619.1779
Krang
Hawaii Classifieds
Mar 31, 2011 11:06 AM
wrx-sleeper
Apr 11, 2007 12:18 PM
RallySportDirect
Engine and Drivetrain
16
Mar 27, 2006 02:34 PM
ewright
20
Oct 8, 2005 11:32 AM
