As always, the *BEST* pricing on ACT and Exedy. Kartboy and STi mounts in stock too.
Old Jun 23, 2006 | 03:53 PM
gruppe-s's Avatar
Hey all,
As usual, we still have the best pricing on ACT and Exedy. If you don't believe us take a look around and compare pricing. Don't be fooled by terms such as Stage 1 or Stage 2; make sure you know exactly what you're getting. If you find better pricing, let us know and we'll beat it. If you don't see a particular combo or item you're looking for, please PM us. Chances are we still have it or can get it.
Accessories:
Kartboy Short Shifter and Shifter Bushings Combo
02+ WRX - $119 shipped
04+ STi - $175 shipped
These components replace the stock shift lever and shifter mount bushings in 1998-2005 model year Subaru Impreza vehicles, including the WRX, Outback Sport, Legacy and Forester. Overall shift throw is decreased by 40% while also eliminating excessive play in the system for a more solid gearchange. This provides a noticable difference and a solid feel. Constructed of CNC'd and TIG welded 4130 Cr-Mo steel and 95A durometer polyurethane. Installs with simple mechanic's tools in under 30 minutes.
Goodridge SS Clutchlines - 02+ WRX - $59 shipped
The Goodridge SS Clutchline (teflon coated) will improve the feel of your clutch. The stock line is made of rubber and is prone to flexing under hard use. This translates to soft and inconsistant feel in your clutch. The Goodridge line will insure that your clutch feels consistant and firm, even under extreme use.
JDM 5th and 6th Gear Close Ratio Conversion Kit - 04+ STi - $319 Shipped for 5/6th Gear Conversion
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios:
-5th Gear - 1.062 (0.971 stock)
-6th Gear - 0.842 (0.756 stock)
Clutch and Flywheel Combos:
1) Exedy Organic Clutch Kit and ACT Steetlite Flywheel (Stage 1)- 02+ WRX
-Clamp Load: 2300 lbs/ft.
-Pressure Increase: 44% over stock clutch.
-Weight: clutch - 14.3lbs, flywheel - 13.9 lbs.
-Ideal for VF series, 16g, and 18g turbos.
$750 Shipped
$1175 Installed!!!
2) ACT HD Street Disc Kit and Streetlite Flywheel (Stage 1) - 02+ WRX
-Torque Capacity: 411 lbs/ft.
-Pressure Increase: 32% over stock clutch.
-Weight: clutch - 17lbs, flywheel - 13.9 lbs.
$649
$1100 Installed!!!
3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 02+ WRX
-Weight: clutch - 17lbs, flywheel - 9.6 lbs.
$699 Shipped
$1119 Installed!!!
4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3)- 02+ WRX
-Clamp Load: 2655 lbs/ft.
-Ideal for 20g and GT30r turbos.
$PM FOR BEST PRICE!!!
5) Exedy Twin Plate Clutch/Flywheel Kit (Stage 4)- 02+ WRX
-Clamp Load: 2205 lbs/ft.
1) Exedy Organic Clutch Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Weight: clutch - 14.3lbs, flywheel - 15.4 lbs.
$925 Shipped!!!
$1350 Installed!!!
2) ACT HD Street Disc Kit and Steetlite Flywheel (Stage 1) - 04+ STi
-Torque Capacity: 475 lbs/ft.
-Weight: clutch - 17lbs, flywheel - 15 lbs.
$855 Shipped!!!
$1275 Installed!!!
3) ACT HD Street Disc Kit and Prolite Flywheel (Stage 1+) - 04+ STi
-Weight: clutch - 17lbs, flywheel - 11.1 lbs.
$879 Shipped!!!
$1299 Installed!!!
4) Exedy Hyper Single Clutch/Flywheel Kit (Stage 3) - 04+ STi
-Ideal for 20g, FP Green, and GT30r Turbos.
5) Exedy Twin-Plate Clutch/Flywheel Kit (Stage 4) - 04+ STi
-Ideal for FP Red, GT30r, and GT35r Turbos.
6) ACT HD 6 Pad Race Kit and Prolite Flywheel - 04+ STi
-Torque Capacity: 608 lbs/ft.
-Pressure Increase: 35% over stock clutch.
$819 Shipped!!!
$1239 Installed!!!
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
*CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)
Old Jun 23, 2006 | 06:39 PM
hey1's Avatar
Car Info: Giant Bowery '84
I'm curious to how long it takes to have the clutch and flywheel replaced.
Thanks.
Old Jun 26, 2006 | 01:02 PM
gruppe-s's Avatar
It takes about 8 hours and the job cost by itself is $430.
Thanks,
Geoff
Old Jun 27, 2006 | 03:06 PM
hey1's Avatar
I pm'd for the price on 1 and 4. I believe.
Old Jun 27, 2006 | 03:40 PM
gruppe-s's Avatar
Cool, thanks.
Old Jun 27, 2006 | 04:46 PM
hey1's Avatar
So will I get a price on the Exedy Hyper Single?
Old Jun 28, 2006 | 11:49 PM
for the wrx
Old Jun 29, 2006 | 02:52 PM
gruppe-s's Avatar
Sorry for the delay on the response. We've just PMed you back.
Thanks,
Geoff
gruppe-s
Jul 21, 2006 12:41 PM
gruppe-s
Engine and Drivetrain
Jul 19, 2006 07:26 PM
gruppe-s
May 1, 2006 07:42 PM
gruppe-s
Apr 25, 2006 11:38 AM
