WRX 5 speed to STi 6 speed Conversion
Old Mar 12, 2003 | 08:29 AM
stratos's Avatar
Car Info: 96' GF w/EJ205
Re: WRX 5 speed to STi 6 speed Conversion
Originally posted by twistedsymphony
I'm really interested in doing this conversion as Auto crossing I'm stuck between 1st and 2nd gear and if you have a WRX 5speed you know there's a significant power gap there, and downshifting to first is a pain
I have used 16" wheels with lower profile tires. It helps a little, hehe, but not a lot.
I looked into shorter gear ratios and as a daily driver the new gears up top would just kill my high way mileage.... so I think droping in a 6 speed is the way to go (plus it's fricken cool).
If you are worried about milage be sure and get a European 6speed as its 6th is just sightly taller than our 5th. The JDM's 6th is actualy shorter our 5th!
ok so my questions:
can you just drop in the 6 speed?
if not what else needs to be changed?
Minimum:
6 speed tranny
6 speed shifter linkage
6 speed propshaft (or I hear an automatic wrx prop is the same)
A 3.90 ring and pinion set for your rear diff.
BADWRX says that you can use your existing flywheel/clutch/presureplate. He also says you can use the 5 speed tranny mount. but if you are going thruogh the trouble to do this I would use the 6 speed versions of these.
also I currently have a kartboy short shift kit with bushings. will that get replaced or will I be able to keep it?
No, the linkage is different
and... if I do up-grade would this be a good opertunity to replace the mounts too since I'll have it all apart?
Most likely, as you'll have the whole tranny off.
Old Mar 14, 2003 | 08:48 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Do a search.
I wrote 4 very comprehenisve articles about this.
mtcs
Sep 25, 2008 08:00 PM
crashnscar
Sep 4, 2007 11:43 PM
Blugin
Cars For Sale
Jan 15, 2005 09:49 PM
boomer
Jul 6, 2003 06:17 PM
RS TURBO
Jun 21, 2003 07:54 PM
