Transmission gurus, need help (w/part numbers and factory tools)
Old Jul 31, 2005 | 05:58 PM
fantabulous11's Avatar
Transmission guru's, need ur help.
hey wassup. blew my trans in my 02 wrx wagon. upon tear down, sheared off all the teeth on second gear and some on the 2nd gear on the counter shaft. after pressing off the gears on the input shaft, on third gear synchro, theres the outer metal ring, the bronze ring, and then the inner metal ring. the small inner metal ring cracked in half. i've been looking at blow out pictures of the transmission on subaruparts, and i dont see this little metal ring. when i order parts, does it come with the synchro assembly? part numbers would be most helpful.
i also need to know where to find the special sockets for the two 6-point lock nuts with the curved corners. the small one is a 35mm i believe. the other is pretty big, didnt measure it. are these sockets availible from subaru?
thanks.
subie OCD
Dec 15, 2010 07:43 PM
ProjekBluBuk
May 19, 2009 02:54 AM
subie OCD
Aug 21, 2008 07:45 AM
subie OCD
Jul 15, 2006 11:48 AM
NewShockerGuy
Aug 24, 2003 06:07 PM
