Trans & rear diff gear oil???
Old Jul 25, 2010 | 01:35 PM
STIWRB's Avatar
Car Info: 06 STI
So im gonna change my trans & rear diff gear oil soon on my 06 sti. I found by google that 75w90 extra-s along with a bottle of syncro magic before hand is what subaru uses. I also read that the rear diff can take any brand of 75w90 synthetic or regular gear oil.
Anyone use any other brand? What have you guys used & what do you recommend? Thanks!
Old Jul 25, 2010 | 01:55 PM
Gancherov's Avatar
Car Info: 02 WRX Wagon
Some people use "Scotty's Cocktail" for which there are several variances in name. I believe that someone sent out a sample of this fluid for analysis and the results were pretty bad. Now, everyone seems to know that this will eventually ruin your transmission.
Another popular choice is Redline lightweight shockproof. This stuff seems to be safe and people have good results. A few people have also done 3qt redline and 1qt regular 75w-90. Not sure what the reasoning is for the 1qt of regular but apparently this is the "professional recommended" route.
do some searches on nasioc, iwsti, and maybe clubwrx.
Old Jul 25, 2010 | 02:08 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
I used this. Ive had 100% no problems with my tranny.
http://www.grimmspeed.com/catalog/ad...words=cocktail
Old Jul 25, 2010 | 02:15 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
Dude honestly go with swepco... I changed my diff and tranny with this about 4K miles and its still amazing... I was unsure since I had never done this before but I called LIC and they said it was a perfect oil and they recomend it, so I was sold
Old Jul 25, 2010 | 02:37 PM
flat489's Avatar
Car Info: '11 STI
swepco makes extra s look really bad
Old Jul 25, 2010 | 04:11 PM
Gancherov's Avatar
FYI: this IS Scotty's Cocktail, the one i mentioned above. I would do some research on the oil analysis that was done before using this. Apparently after some period of time it turns acidic and causes issues.
I'm not saying this to knock anyone or start anything, just a warning that people have had issues with this mix and that you should do your own research and use at your own risk.
Old Jul 25, 2010 | 09:13 PM
STIWRB's Avatar
Car Info: 06 STI
Thanks for the replies... i will check all of these options out.
slow04wrx
Oct 10, 2010 04:30 PM
bmxhotsauce
Aug 10, 2008 10:25 PM
willl
Mar 10, 2007 04:50 PM
cleofis
Jan 14, 2005 01:42 AM
minisiu
May 17, 2003 09:00 PM
